how to take off oil filter housing
Old Apr 26, 2013 | 05:14 PM
evoson23's Avatar
look for some advise how to take off the oil filter housing in a evo 9. I crack mine by the oil pressure sensor.
Old Apr 26, 2013 | 05:30 PM
hiboost2.0's Avatar
Pretty sure you have to take off the lower timing cover to get to some of the bolts. Other than that it's extremely simple and straight forward. Make sure to get a new gasket, and DO NOT apply a gasket maker to it.
Old Apr 26, 2013 | 05:43 PM
evoson23's Avatar
how do you get the belt loses
Old Apr 26, 2013 | 05:55 PM
hiboost2.0's Avatar
Come on man, I found this on google in less than 5 seconds.
http://www.joe250.com/cars/evo8/belt...ltremoval.html
joseph143's Avatar
take a 1/2 rathet or breaker bar put it in the notch and turn counter clockwise...
put a allen or small screw drive in the holes in the bottom when they line up...
to pull the front cover you need to also remove the water pump and crank pulley. then you have to remove the 8-10 bolts in the front cover.
after its off there is two bolts in the tension itself to remove one is a 12 the other is the pivot of the tensioner and its 14mm... pull those and its been awhile but there should be 3 more bolts plus the oil cooler lines to remove the filter housing...
94AWDcoupe
182
Feb 17, 2025 10:42 PM
DSM725
Lancer Engine Tech
Sep 8, 2016 02:22 AM
coloradoboost
Jul 26, 2015 04:41 AM
etown09
Apr 13, 2013 02:16 PM
taylorgang
Jul 17, 2011 04:47 PM
