thinking my EBC was the radio, she blew my engine!
Old Feb 19, 2004 | 12:59 PM
mikec's Avatar
Just one more reason to use a MBC.
Old Feb 19, 2004 | 01:03 PM
Chris in HB's Avatar
The Power Enterprise boost gauge/controller solves that problem since it's in the gauge itself.
Old Feb 19, 2004 | 09:10 PM
evo542's Avatar
the EBC will not go over the warning that is currently set at, unless one purposely messes with them
Old Feb 19, 2004 | 09:33 PM
Conduit's Avatar
I like to have a valet/family setting on mine. It limits the turbo to 7psi, just in case.
Of course, it will be a cold day in hell when I let a valet drive my car...
Old Feb 19, 2004 | 09:51 PM
Creamo3's Avatar
Don't let anyone else drive your car, if you're worried about it, put the controller somewhere out of reach ie. drivers side or glove box
Old Feb 19, 2004 | 10:06 PM
Want to Evo's Avatar
Damn you beat me to it.
Old Feb 19, 2004 | 10:09 PM
EVO8 WHOA's Avatar
first off, if he/she does tamper with it, most likely they are gonna say somthing while "trying to turn the volume up" and if you know they turned yur boost up then just dont floor it and you will be fine, its not gonna blow just turning it up, you have to apply the peddle big time to build enough boost to blow the motor, thats how it is for my evo at least... i can set my boost control to 20lbs and I wont hit that unless its peddle to the floor 3rd gear or so.
Old Feb 20, 2004 | 06:03 AM
S2L's Avatar
S2L
Re: thinking my EBC was the radio, she blew my engine!
Originally posted by budlong
has this ever happened to anyone? is there a way to lock an ebc so it cannot be tampered with? I can totally see someone tweaking your boost setting without you knowing, which could lead to ...BOOM.
just curious if anyone has experienced this..
BUDLoNG
take her to the car...show her where the controls are for the EBC and look her straight in the eyes and say.." Hun, if you mess with the settings on this box...you will not only destroy our relationship, but you will blow my engine and hurt me in a way that make a kick to the nuts a trivial experience." And if she loves you, she'll wont touch it.. and if you **** her off in the future.. you better make damn sure the settings are correct before you go street racing...or put it behind a plexiglas window with a sticker that says " DO NOT TOUCH!..I did both..
Old Feb 20, 2004 | 06:25 AM
evo8ya's Avatar
wow that would suck so bad if that ever happened to anyone
Old Feb 20, 2004 | 07:17 AM
justchil's Avatar
Originally posted by treffner
"she" wouldn't be driving the car. thats your first mistake
Exactly!
Old Feb 20, 2004 | 07:30 AM
jbrennen's Avatar
Originally posted by gtr
I think the stock ecu will hit fuel cut at 1.5bars. Now a days the ecu is quite good in protecting your engine.
I think gtr has the right answer. As long as the stock ECU is present and you haven't messed with the MAF sensor or the MAF signal, you'll hit fuel cut long before you blow up the engine.
If you're running 91 octane gasoline, I imagine there might be a range of boost, still below fuel cut, where you'll have some knock problems -- but again, the stock ECU should detect the knock and either pull timing or enrich the mixture.
Old Feb 20, 2004 | 11:32 AM
MrBonus's Avatar
Not necessarily. If you're using an MAF device for fuel control or have modifications to your fuel system, you're essentially raising the factory fuel cut. Remember: Our cars DO NOT have any MAP sensor or anyway to detect manifold pressure.
The person who mentioned the "Warning" settings is correct, however. If the duty cycle on my Evo was turned up to something that would produce, say, 25 PSI, it'd hit the warning at 23 PSI and reduce the duty cycle to 10% (Which equates to about 12 PSI of boost).
Old Feb 20, 2004 | 11:58 AM
jbrennen's Avatar
In that case, you've "messed with the MAF signal" ...
Old Feb 20, 2004 | 12:36 PM
MrBonus's Avatar
Messing with the MAF signal is cheap. AEM EMSs are expensive.
BoostedFODO
Apr 19, 2018 12:18 PM
MoorzyRalliart
Apr 3, 2016 10:36 AM
lookitznite
16
May 31, 2011 08:15 PM
Wick3d3vo9
Apr 7, 2009 04:17 PM
budlong
Aug 24, 2004 01:21 PM
