gearstick movement in first
Old Apr 29, 2013 | 08:22 AM
thedragon's Avatar
I recently changed my clutch and put in a trq damper.. now when i put the car in first and start to move the gearstick moves back and forth almost looks like its going to pop out of gear... this has got me worried. any help on y this is happening and how to remedy it will be greatly appreciated thanks
Old Apr 29, 2013 | 11:50 AM
thedragon's Avatar
bump... anyone?
Old Apr 29, 2013 | 02:32 PM
r3dtr1ckz's Avatar
bump
Old Apr 29, 2013 | 11:14 PM
hatesposers's Avatar
It's your engine moving that is causing the gearstick to move...
are you sure the rest of your engine mounts are good?
Old Apr 30, 2013 | 06:35 AM
thedragon's Avatar
im going to check the mounts today
Old May 3, 2013 | 10:35 AM
MechTech's Avatar
What kind of clutch is it? Sometime a heavy clutch with harsh engagement can cause excess shifter movement on take off. Try taking off at a slightly higher rpm. I know sometimes when I bog from a start the shifter with jiggle a little. Go back and recheck your work would be first thing to do.
Old May 4, 2013 | 11:58 AM
thedragon's Avatar
comp clutch stage 3.5 ... i checked all mounts and shift linkage everything is tight... im going to change the bushings and see if that helps
Old May 7, 2013 | 10:32 AM
MechTech's Avatar
That sounds like the next logical step. When you say torque damper which mount are you refering to? Only reason I ask is if one mount is now super stiff and another is stock then that stock mount is going to move more because the other one is now flexing as much. Does it feel like the shifter is popping out if your grabbing it when you take off? I'm not really sure where else you could go after shifter base and linkage bushings.
Waffled
Oct 27, 2014 06:12 AM
Harumsevo
Jul 30, 2013 05:19 PM
anasyakoub
Oct 27, 2012 11:59 PM
nytalonTSi
Jul 27, 2011 10:26 AM
Sloop
May 18, 2004 10:43 AM
