P0234 and P0507
Old May 8, 2013 | 04:07 PM
ragyan03's Avatar
P0234 and P0507
Scanned my car and these two codes came up..first one has something to do with the iac and the second one has to do with the Wastegate..I've already searched google and haven't found an answer..can anyone help me fix this? I don't know what to look for and i don't wanna spend money if i don't have to..this is for emission purposes
Old May 9, 2013 | 03:40 PM
ragyan03's Avatar
Anyone?
Old May 9, 2013 | 03:50 PM
ProPilot04's Avatar
Ragyan...
P0234 is a wastegate system malfunction, and depending on how or if it's failed, you could over boost your turbo (that's bad).
1. Do you have a boost gauge? Does it appear to be reading normally?
2. The 2 components that can cause this code are:
A. The wastegate actuator (This can be inspected visually, and by using pressure)
B. The charging pressure control system (This needs to be checked with a voltmeter)
Honestly... I'm not too familiar with the proper technique of checking either. It could be as simple as a vacuum hose popping off (in my head it could anyhow).
P0507 is for your Idle Air Control System.
It could be as simple as a dirty IAC, throttle body, or simply a vacuum leak.
I would start by telling us what mods your car has, what, if anything was recently done, and I would do a PROPER, and thorough boost leak test. Fix any vac leaks, and clear the codes and report back.
Old May 9, 2013 | 04:44 PM
ragyan03's Avatar
dnp manifold
atp gt30 dbb
jmf open dump
3'' dp to 3'' buschur exhaust
1200cc pte injectors
walbro 255lph
ETS licp, FMIC
forge BOV
hallman mbc
I have a boost gauge and it reads fine..stays at 20 vac during idle and the usual 5-7 psi of
boost while driving normally..
My WGA looks good..doesn't look damaged at all..also my mbc goes like this, WGA to mbc, intake t fitting bov to mbc...im not sure if that makes a difference..i also dont have the stock boost solenoid either.
What is the charging pressure control system and how do i check for that?
Ill clean my TB this weekend and do some research on how to clean the IAC..thanks ProPilot
Also my car is not tuned at all and i don't do WOT pulls..in the process of getting a tune
Old May 9, 2013 | 04:50 PM
ragyan03's Avatar
Forgot to mention that my car holds 28 psi when i did my boost leak test..and the shop that did the test told me that i need to get me a new o2 housing gasket because i was using the oem one and also they told me that i had bad TB shaft seals..but if it was bad wouldn't i be under 28 psi during the boost leak test?
Old May 9, 2013 | 04:57 PM
ProPilot04's Avatar
TB seals could be causing this. They commonly go bad on Evos, but you are correct... if you're checking the seals during the boost leak test, it wouldn't hold 28psi.
Do a quick search for how to check your TB seals. I'm about to head out... maybe someone else can chime in.
Old May 9, 2013 | 07:58 PM
ReidFletcher's Avatar
Wastegate code is coming up because the stock boost controller is unplugged(people do silly things when installing a mbc). Think about it; with an MBC, how would the computer know you have an mbc? Aha
Old May 10, 2013 | 04:18 PM
ragyan03's Avatar
yea...The Car didn't Have One With It When I Bought It..And The Turbo set Up Only HaS About 6K Miles And I rarely Ever Hit Boost
narpoon
Feb 15, 2015 06:19 PM
powerdriver
Jan 31, 2013 06:38 PM
lemacfar
Feb 21, 2010 10:13 PM
LanEvo03
Apr 19, 2008 07:15 AM
