Headlight taken apart - Need Help
Old May 12, 2013 | 06:12 PM
TIGERJC's Avatar
The previous owner of my car did the headlight mod, however he did not do a good job sealing it back up. I used a heat gun and got the headlight apart, but I am trying to figure out the best way to get rid of the sealant mess so everything lines back up when I put it back together.
Is there a solution that can help in the removal and what type and brand sealant should I use to seal it back up? Also the reflector in the second pic looks like it was glued to the housing with gorilla glue. Is there a better adhesive I can use so that it won't turn yellow like in the pic?
Attached Thumbnails Headlight taken apart -  Need Help-headlight.jpg   Headlight taken apart -  Need Help-headlight1.jpg
Old May 12, 2013 | 06:41 PM
lostsoulsevo's Avatar
use your heat gun and acetone to remove sealant from lens. do not use on the headlights if they are painted
Old May 13, 2013 | 05:57 AM
bhmax's Avatar
I used oven before disassembly and reassembly. This allowed it to go back together easier without having to remove all the sealant. I just used regular silicone sealant, but someone mentioned butyl rope working better. I didn't get a chance to try it, but might in the future.
Old May 13, 2013 | 06:08 AM
flippymcbean's Avatar
i dont know about removing the stuff, but i wold really reccomend this
http://www.theretrofitsource.com/pro...roducts_id=792
i used on my subaru retrofit. no problems yet...but i dont have the car anymore.
Old May 13, 2013 | 08:45 AM
TIGERJC's Avatar
Thanks
Old May 13, 2013 | 09:22 AM
1hotevo9's Avatar
I use a heat gun and Goo Gone, it worked for me.
Old May 13, 2013 | 07:46 PM
awdordie's Avatar
If he hadnt gotten the silicone everywhere you can install the lens without using additional silicone like i did. I bought a new tube and its still sitting in the package. I would try heating it back up and using rubbing alcohol.
Chrushev
Lancer Troubleshooting
Feb 23, 2017 11:32 AM
Mweisel
Jul 23, 2015 07:52 PM
kelvar13
Evo X How Tos / Installations
38
Apr 3, 2015 05:43 PM
600+hp
May 25, 2012 11:34 AM
MSP608
Nov 13, 2011 08:00 AM
