Tapping for fuel pressure?
Old May 12, 2013 | 08:41 PM
Grimgrak's Avatar
Where do people typically tap for a sensor on these cars? No banjo for a fuel filter on the firewall like dsms.
Old May 12, 2013 | 08:55 PM
TSiAWD666's Avatar
On the regulator.
Old May 12, 2013 | 08:59 PM
lostsoulsevo's Avatar
Originally Posted by TSiAWD666
On the regulator.
+1
Old May 12, 2013 | 10:08 PM
Grimgrak's Avatar
Is there an adapter plate for the oem regulator?
Old May 12, 2013 | 10:25 PM
no, you need an aftermarket fpr
Old May 13, 2013 | 09:27 AM
Grimgrak's Avatar
Is there a kit that is meant for the stock rail/return?
I'm liking the AEM fuel rail, wont need a regulator and has a 1/8npt port.
I'm not shooting for more than 600whp on a mustang dyno so there is no need for a regulator since I run a 91 octane + methonal setup is there?
Old May 13, 2013 | 10:35 AM
Grimgrak's Avatar
Another thing that worries me is having a FPR that wont hold pressure when the car is off. I love my quick oem style starts which is why I would rather side with the aem fuel rail than risk messing with my cold start fuel pressure. Are there certain brands known for not holding cold pressure?
Old May 13, 2013 | 01:13 PM
http://streettunedmotorsports.com/pa...proclassic.htm
use this kit, instead of using this pressure gauge, thread in yours...i'm assuming you have a digita/anolog in cabin gauge? i've never heard a car losing pressure when its off? new to me
Old May 13, 2013 | 02:48 PM
TSiAWD666's Avatar
Some AFPRs aren't designed well to hold pressure, and will leak when the pump is off returning line pressure back to zero. I have an Aeromotive one for example on my DSM that does this. Just results in perhaps a bit longer cranking but really not anything terribly noticeable. I've written it off as a non-issue for now but do wonder if there is a quantifiable impact on peak fuel flow from the pump since some effort is being used to generate the bit of extra pressure lost from the "leaky" afpr.
Some AFPR don't leak though as quickly, probably similar to stock. I've seen a few of these firsthand, some of them being other Aeromotive designs. Different ball seat I'd imagine, or perhaps one better machined. Mine is a 90-degree seat which I imagine is a bit more difficult to get perfect in order to seal on a ball bearing as opposed to a conical seat.
Old May 13, 2013 | 06:08 PM
ExViTermini's Avatar
I have the kit he linked you to, and it does fine as far as holding pressure, it will maintain some overnite. If you search the intronet some(I can't remember where I found it), there is an adapter that goes between the rail and the fuel line(input, two bolts), and has an NPT port on it. That is how the factory test tool works, you can see it in the manual.
Old May 14, 2013 | 05:18 AM
Fast_Freddie's Avatar
Veteran: Navy
^that one is the unorthodox racing gauge adapter... I had one but always seemed to leak after a while as it would chew up o rings...
Another option us from 3SX Racing... with guage it is like $55...
Old May 14, 2013 | 09:54 AM
90zcrex's Avatar
Yes there is a kit to use the stock FPR.
http://www.fftec.com/item/35/FFTEC_M...r_Adapter.html
black_beauty
10
Feb 5, 2013 01:34 PM
jrod4484
Jun 2, 2011 08:58 PM
OTchie
Dec 10, 2007 01:52 AM
dudical26
16
Jun 6, 2007 12:13 PM
ZeroFrost
15
Sep 16, 2004 06:50 PM
