Leak into drivers foot well
Old May 13, 2013 | 08:18 PM
danny_boi's Avatar
Hey guys im new on this forum thing I would love it if some one could give me a bit of advice on a problem I have in my 1996 Evo 4.
I have a leak (rain water) into my drivers foot well, I have located it to the right side of the drivers foot well (right hand drive) it is running down the the side of the inside body behind the wiring loom, i have pulled off the dash, quarter panel, silicon-ed up where all the wires run through the firewall, with no luck on locating the source of the leak, it also does no look like and instant leak its seams like the water maybe tracking because it does not leak straight away.
Would be much appreciated if some one has had a problem like this and could give me some advice on where I should b looking.
Cheers Dan
Old May 13, 2013 | 09:39 PM
superbovine's Avatar
If it definitely isn't anything obvious like the windshield or door seals, try pulling the fender liner back and spraying behind the fender. I've seen the seams separate back there.
Old May 13, 2013 | 09:46 PM
ak47po's Avatar
Cheers Dan
https://www.evolutionm.net/forums/ev...-warrenty.html
Old May 13, 2013 | 10:16 PM
MileHighX's Avatar
Like posted above, check under your fender liner. I know on the 8s and 9s the loom goes through a plastic box at the top of the arch, and it isn't very water proof. I just had my second battle with the electrical gremlin
Old May 25, 2013 | 10:28 PM
danny_boi's Avatar
cheers for that guys, sealed the loom as much as i can we will see if it still leaks
stealthlancerOZ
Lancer Troubleshooting
52
Sep 19, 2014 10:17 AM
awdordie
12
Apr 21, 2014 04:33 AM
Astro_Train
10
May 30, 2013 02:33 PM
ggevo23
Jan 11, 2013 08:30 PM
bowlersp
Sep 8, 2010 08:42 AM
