what motor do i have?
Old May 27, 2013 | 06:46 AM
sslater88's Avatar
I joined here a while back looking for a motor for my 03 evo. I finally found one at a shop about an hour away. They sell only motors/transmissions torn out of cars.
they showed me the motor and everything looked perfect identical to the motor i pulled out. I didn't even think to check numbers on it.
After I bought it, it sat for a few months before I started messing with it, figured I would do the water pump and timing belt while it was out and easy to move around. But the water pump is actually bigger than the one I had ordered for an evo 8.
I had found a list of engine stamps somewhere in this site but it doesn't show the numbers stamped on this motor. They are GD 8387
What motor is this and will it work? everything looks right on it...
Any help would really be appreciated
Old May 27, 2013 | 08:59 AM
donzilla2004's Avatar
Do you have any pictures of the engine? There should also be a stamp on the block somewhere that will say 4g63
Old May 27, 2013 | 09:04 AM
TeRoy EvoIX's Avatar
Sounds like you may have a 4G64
Old May 27, 2013 | 10:25 AM
llDemonll's Avatar
Just get the vin off the block and run a check on that
Old May 27, 2013 | 11:12 AM
superbovine's Avatar
Yep, get the VIN off the bellhousing area just below where the head meets the block. The number you posted is just a serial number and you can't do a reverse-look up on them. You need the VIN.
Old May 27, 2013 | 01:59 PM
sslater88's Avatar
where it says GD 8387 it also says its a 4g63. I'll have to look for the VIN number.
Old May 28, 2013 | 08:19 AM
Are we sure you just didn't get the wrong waterpump? Do you have a part number for the pump? Just ruling out the obvious sometimes these things happen.
Old Jun 6, 2013 | 12:42 PM
spiXel's Avatar
If it says 4g63 it is an evo motor and you're all good. probably wrong oil pump
Old Jun 6, 2013 | 12:46 PM
heel2toe's Avatar
Just because it is a 4G63 doesnt mean its an evo engine...
Old Jun 6, 2013 | 12:55 PM
4RETECH's Avatar
Exactly^^^^^^
get the Vin off the block to confirm
Old Jun 6, 2013 | 08:47 PM
xXevo8RavenXx's Avatar
+1 for looking up the vin. there a few 4G63's
Old Jun 6, 2013 | 08:53 PM
evoDON's Avatar
Is there anyway that you could post a picture of the engine itself? the first question i would have, assuming you got a long block, is what does the valve cover look like? every other 4g63 has a different valve cover from our evos. That would be a big tell tale sign. If you bought a short block, then you will have to locate a vin
Old Aug 27, 2013 | 12:28 PM
NoobSybot's Avatar
where did u find a list of engine stamps?
Live4Redline
Mar 27, 2026 01:19 PM
BrunoBoy650
Feb 27, 2014 12:10 PM
NJ_EveOhVIII
Sep 6, 2013 06:34 PM
17pstockcar
Aug 17, 2012 11:12 AM
TakaseEVOIXSE
24
Jan 29, 2011 08:39 AM
