Evo viii up down temperature problem
Old Jun 25, 2013 | 10:04 AM
Big Lex's Avatar
Question Evo viii up down temperature problem
Hi
I have a 2003 Evo VIII MR. I just got it it has 39k on the clock.
I getting some strange temperature reading when im at high RPM and withing 4 seconds after easing upoff the rev it goes back to normal which is about 1/16 below half. ANY IDEAS AS TO WHATS CAUSING THIS UP AND DOWN TEM PROBLEM?
Its frustrating not being able to drive my car as i should
Old Jun 25, 2013 | 10:11 AM
crazybaldhead's Avatar
Check you grounds. Sometimes when the fan comes on, the temp sensor for the dash gauge loses the ground a little. The culprit is usually the ground on the side of the head near the headlight on your right when you are looking at the car. Try and run a direct ground to here from your battery and see if that helps.
If you temp really is rising, could be a num berr of more serious issues, but try that first.
Old Jun 25, 2013 | 10:52 AM
egis's Avatar
https://www.evolutionm.net/forums/sh...8#post10858658
something similar? i hope yours not.good luck
Old Aug 7, 2013 | 12:20 PM
Big Lex's Avatar
I had a bad T-Stat. got a OEM my car is fine ... dammm you Stat. lol
Old Aug 7, 2013 | 03:44 PM
barneyb's Avatar
Log it and check if you see the temperature rise there.
Old Aug 7, 2013 | 09:53 PM
SmittyPNW's Avatar
If its just the dash gauge it could be the temp sensor on the t-housing.
Old Aug 7, 2013 | 11:07 PM
slammedndirty's Avatar
I am going to guess there is something wrong with the connection on the temp sensor.
gagge
Oct 7, 2016 11:36 PM
Kins
Jan 31, 2016 07:20 PM
bellacotim
Dec 25, 2013 04:47 AM
hatakashi
20
Oct 22, 2011 09:30 AM
05_VIII
Sep 29, 2011 12:46 AM
