Opinions on door handles
Old Jun 26, 2013 | 02:53 AM
Viegasjuice's Avatar
Long story short, doors handling paint is chipping. I'm gonna assume the paint used on the door handles is very thin because it flakes off super easy and all I see is white. Wondering if I tape off everything really well and take aircraft stripper to it, wil it accomplish the Job of leaving the entire door handle completely white or will it kinda melt the white plastic? Ideally I would like to do this to all the handles and achieve a bare, white plastic look...see if I like it, and if I don't i will order Oem spray paint from automotivetouchup.com
Old Jun 26, 2013 | 09:33 AM
jspecteggy's Avatar
I wouldnt recommend it, its very likely to melt your plastic handle since its meant for aluminium. If you did do it youd have to watch it closely the entire time and rinse it off as soon as you see the paint start to wrinkle up/off..I'd rather chip or sand the paint off IMO
Old Jun 26, 2013 | 09:42 AM
gsx1992's Avatar
I would avoid that stuff as well. I would go with the touch-up route.
Old Jun 26, 2013 | 10:00 AM
sujinX's Avatar
ive used the aircraft paint stripper before, its near impossible to know exactly what its going to do. it ate everything and then some when i used it. then on other spots it didnt do anything. u still have to do a bit a scrubbing as well.
do paint touchup.
Old Jun 26, 2013 | 10:55 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You will destroy the handle if you do that. It's plastic, so you might want to touch it up or have it resprayed if you're that OCD about it.
Old Jun 26, 2013 | 04:23 PM
I figured. Should I just sand the paint down real good then repray it
Old Jun 26, 2013 | 07:22 PM
jspecteggy's Avatar
That would be the best way if you're gonna respray it, so the paint sticks to the handle itself and not the paint that was already on there.
Old Jun 26, 2013 | 07:36 PM
hatesposers's Avatar
Just dont spray it with a 1K (AKA rattle can) paint, or it will come off again in no time.
Old Jun 26, 2013 | 08:02 PM
Im ordering from automotive touchup. Whats the fastest/easiest way to get it down to the plastic?
Old Jun 26, 2013 | 08:29 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You can try Castrol Super Clean.
Old Jun 26, 2013 | 11:38 PM
Does it work as good as advertised
Old Jun 27, 2013 | 10:33 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
A quick google search shows that it works pretty well, but YMMV.
I would do some research first before you begin, but I think that would go without saying.
Good luck.
Old Jun 28, 2013 | 09:31 AM
thepoint4life23's Avatar
Could you just find door handles off a parted out evo
GSRwithRotas
Jul 3, 2013 08:04 AM
Viegasjuice
Jun 20, 2013 11:02 PM
BoostedAWD91
Mar 28, 2013 11:21 AM
powerspeed06
Jul 23, 2011 02:55 PM
Evo1001
Sep 1, 2009 09:47 AM
