After I changed the engine oil:(
Old Sep 2, 2013 | 03:50 PM
eddy5201314's Avatar
Hi all, I went to mitsubishi for full service yesterday, after it been done, I took it for a drive and I found that my car proformance not as good as before and the lifter getting lounder, I use the GTX 15w40 oil, before that I used the 5w30, is that ture that I can't use 15w after I been using the 5w30? Its an Evo 5...What should I do?
Old Sep 2, 2013 | 05:09 PM
adriano_917's Avatar
Why 15-w40 ???
Old Sep 2, 2013 | 07:16 PM
Originally Posted by adriano_917
Why 15-w40 ???
I took it to mitsubishi dealer, they changed it for me, is it bad for engine?
Old Sep 2, 2013 | 09:09 PM
osetsky's Avatar
It can be.
Drain it and put lighter oil in. Heavy/high vis oil like that will likely cause high pressure and beat on your everything. Take it back and complain. I would not go WOT with that stuff in there though.
Old Sep 2, 2013 | 09:11 PM
Magrud3r's Avatar
I recently switched from 10w-40 to 20w-50 and only noticed the car is a bit quieter at idle.
Old Sep 3, 2013 | 02:26 AM
Originally Posted by osetsky
It can be.
So are you saying 15w40 is bad for my engine? Should I take it back and ask for refund?
Old Sep 3, 2013 | 03:46 AM
ray3328's Avatar
For a stock engine I would only use 5w30 and 10w30. 15w40 might not give you proper lubrication on a stock engine.
Old Sep 3, 2013 | 07:01 AM
VWJETTY's Avatar
those dealership kids are jokes
pckiller00
Sep 24, 2015 11:40 AM
Lodus
Nov 8, 2014 11:30 AM
04Evo851374
May 29, 2014 08:50 AM
ImsoevoX
Sep 12, 2011 04:41 PM
dambikeracer
34
May 4, 2011 05:13 PM
