Turbo Removal Help.
Old Sep 15, 2013 | 10:32 AM
Randal's Avatar
Guest
Turbo Removal Help.
So I need to check out the condition of the Hotside impeller but don't really want to remove the turbo, down pipe etc etc. is there any way to just removing the cold side and Hotside impeller together? Maybe removing the clamp in the middle?
Old Sep 15, 2013 | 10:47 AM
06ebevo's Avatar
remove intake, remove lower ic pipe, remove downpipe, remove oil drain line from turbo and pan, unbolt turbo from manifold and slide to the right. don't be lazy, you'll be sorry.
Old Sep 15, 2013 | 12:52 PM
todd6027's Avatar
remove front o2 sensor , borescope in through o2 sensor hole
Old Sep 15, 2013 | 12:55 PM
timmycat's Avatar
maybe
maybe take off the o2 housing
Old Sep 15, 2013 | 01:22 PM
slowsrt4:('s Avatar
It's honestly easier to unbolt the down pipe and lines then remove the manifold turbo and o2 housing all together
Old Sep 15, 2013 | 01:28 PM
Randal's Avatar
Guest
Genius !
Old Sep 15, 2013 | 02:21 PM
egis's Avatar
rent borescope at rental maxx,cause HD don't have it for rent.
Old Sep 15, 2013 | 08:32 PM
Randal's Avatar
Guest
They sell them on Ebay, borescope with LEDs, its USB powered and plugs right into a laptop and brings the driver. $12 !
Old Sep 16, 2013 | 03:40 AM
egis's Avatar
crazy deal! lol
Old Sep 16, 2013 | 05:46 AM
impact blue's Avatar
There's a diy on YouTube by don'tstopme that is the name of the user there you shall find how to remove the turbo,transfer case and such on there.
Old Sep 18, 2013 | 06:19 PM
echofive's Avatar
I wish I would have though of that, I'm buying one today lol.
Old Sep 18, 2013 | 06:30 PM
deylag's Avatar
It only takes about an 1.5 hours to remove the turbo if you know all the steps. If you have a Evo 8 turbo and it has a lot of miles it might be a good idea to remove the turbo and the 02 housing and replace all the gaskets. Exhaust leaks rob power.
walker992
13
May 10, 2016 07:05 AM
►EvolutionX◄
May 31, 2015 09:10 AM
nzevo8
Jan 2, 2014 12:09 AM
hernameisstella
10
Feb 2, 2008 08:50 AM
alleggerita
Future Lancer / Evo Models
26
Sep 20, 2005 12:00 AM
