ac delete belt
Old Oct 11, 2013 | 08:48 AM
evohmoob's Avatar
ac delete belt
noob question since ive just got the car
so its getting close to the fall where i dont need my ac anymore
so can i run the ac delete belt without taking the ac unit out so when it hits summer again i can just put on the regular belt again.
I read alot about other evo owners taking their whole unit out but none to answer my question
Thanks
Old Oct 11, 2013 | 09:14 AM
shrtstuff89's Avatar
theres really no point in replacing just the belt to get rid of a/c for the winter, just to put the other one back on next summer. ppl who remove the units do so because of weight reduction, not because they dont want a/c for the winter.
yes, you can run it with the RS accessory belt, but again, whats the point of doing it just for the winter to put the regular one back on next spring
Old Oct 12, 2013 | 06:19 AM
tsidrift1's Avatar
I believe if you just tried to run a non ac belt with the compressor still installed, the belt might rub the pulley on the compressor, the back side of the belt might rub.
Old Oct 12, 2013 | 10:29 AM
TommiM's Avatar
with the a/c compressor off the a/c pulley free wheels and shouldn't have any effect. it should be the same as bypassing the a/c with a delete belt. Yes you can bypass the a/c with it still bolted on, shouldn't be a problem. BUT, unless the compressor pulley is seizing, no point imo
Old Oct 12, 2013 | 02:11 PM
06mr775's Avatar
It is pointless to do it, on top of that even if it did work most places dont carry a belt that length and have to order it. I had a hard time finding one for my car
Old Oct 12, 2013 | 02:31 PM
TommiM's Avatar
Theres a few threads on here that have the part numbers for the napa belt. I posted in a few of them but I don't have that number off the top of my head. Napa had plenty in stock, Im sure most auto parts stores will. I guess maybe your bad luck is maybe that in certain regions, certain stores may not get same inventory though, idk.
Its pointless to do unless your either diagnosing a concern or removing the compressor along with it.
Old Oct 12, 2013 | 09:00 PM
AJCaron12's Avatar
I removed all the A/C components from my Evo and used this belt: http://www.streettunedmotorsports.co...moval_belt.htm
Old Oct 13, 2013 | 05:04 PM
tsidrift1's Avatar
This is the part number for the belt thats on my car.
k060578 gates belt.
Old Oct 13, 2013 | 06:11 PM
Blue Evo 8's Avatar
I am an old school Honda guy from the mid 90's and run the shorter a/c bypass belt just for the heck of it. At the very least the belt has one less pulley (a/c compressor pulley) to spin.
I can swap belts back and forth in less than 15-20 minutes, so its no biggie for me. I also get about 300 miles per tankful of mostly highway with some local driving.
Old Oct 13, 2013 | 06:35 PM
detroit pistins's Avatar
The benefit of spinning the motor with one less pulley is in the reduction of the internal friction torque. having said that, unless you are chasing every ounce of fuel saving then it would be tough to quantify.
usnevo8
Aug 24, 2019 03:05 PM
Celica2EVO
71
Sep 7, 2017 11:03 AM
eisnikesb
May 19, 2014 07:41 PM
neilschelly
Lancer Engine Tech
10
Dec 22, 2012 02:36 PM
Chu's Mom
Oct 24, 2011 05:32 PM
