random bracet nothing goes to on my engine??
Old Dec 17, 2013 | 04:32 PM
vito93's Avatar
I have this bracket that has nothing going to it? I just got the car not to long ago and I didn't realize it then if anyone can help it would be much appreciated.....
Old Dec 17, 2013 | 04:47 PM
bvliz's Avatar
engine hoist bracket
Old Dec 17, 2013 | 04:50 PM
vito93's Avatar
Maybe a dumb question but does anything go to it
Old Dec 17, 2013 | 04:54 PM
TommiM's Avatar
Some chains with a hook to pick up the engine.
Old Dec 17, 2013 | 04:57 PM
vito93's Avatar
I figured as much I just wanted to make sure it didn't have multiple purposes
Old Dec 17, 2013 | 05:11 PM
TommiM's Avatar
nope. I guess you can unbolt it if it bothers you. Unless your lifting the engine it doesn't really have a purpose. I took mine off.
Old Dec 17, 2013 | 05:22 PM
wc351's Avatar
Should be another one diagonal to this one on the other side of the engine.
Old Dec 17, 2013 | 05:34 PM
vito93's Avatar
Thanks for the help.... The only reason it bothered me is because I noticed it after I got it back from the tuner
Old Dec 17, 2013 | 05:41 PM
wc351's Avatar
How much power did it make?
Old Dec 17, 2013 | 10:18 PM
vito93's Avatar
I haven't had it on an actual dyno just virtual dyno but soon I will I trapped 116 in the 1/4.... I don't have much done e85, short route inner cooler pipe, 25psi wga, tbe, injectors, Wally, mbc, and a tune
Old Dec 17, 2013 | 11:13 PM
evotuner04's Avatar
15 Year MemberLikedLoved
Old Dec 17, 2013 | 11:36 PM
kpt6's Avatar
nope. I guess you can unbolt it if it bothers you. I took mine off.
Weight reduction!!!
Old Dec 18, 2013 | 05:08 AM
slowsrt4:('s Avatar
Unbolt it but try to hold onto it
Old Dec 18, 2013 | 05:57 AM
chu's Avatar
chu
Yup, def nothing you want to lose.
I loosened the nut, and turn it down 90 degrees, but left it on. Came in handy 6 years later when I had to pull the motor.
Old Dec 18, 2013 | 06:56 AM
TommiM's Avatar
Originally Posted by kpt6
Weight reduction!!!
Ya, too bad that has been counteracted by the weight Ive gained since I got married.
vito93
Apr 17, 2016 11:51 AM
michaelrc51
Nov 1, 2015 04:13 PM
vito93
Aug 6, 2015 08:50 PM
MackeyLancerFix
Mar 21, 2015 07:44 PM
The_Predat0r
Dec 14, 2005 05:52 AM
