Question/Concern regarding brake pads.
Old Jan 10, 2014 | 08:29 AM
Grimgrak's Avatar
Originally Posted by Bhsj13
honestly, i would not buy from autozone. You should get some stoptech's man.
Stop techs for evo are garbage. Zero cold stop emergency bite. Over heat easily.
For noise I got some rubberized shims they were pricey but solved any noise issue I had
Old Jan 11, 2014 | 08:10 AM
Syringe's Avatar
They were powder coated.
I went and tried to bed them in properly based on the information I found on the internet (multiple sources) to the best of my ability while being in a city. It seemed to help a bit.. but not a lot.
My next step is probably having the rotors turned / different pads. I still have the old pads that came off it when I replaced it, there is plenty of material - I replaced them cuz a friend made a suggestion that they had little material left, and me being a car rookie instead of checking for myself, believed them.
Old Jan 13, 2014 | 09:30 AM
GTijoejoe's Avatar
In that picture it appears the pad abutments are painted over, they should be removed and then reinstalled after paint, or replaced.
The clearances in a caliper for pads are very important, and it can make the difference of noise or no noise. Caliper NVH is a very very crazy sensitive thing, it also is more common on aluminum and fixed calipers, so that also is not in your favor.
Ayyrock
Jul 20, 2015 04:47 PM
Raptord
26
Dec 11, 2011 02:04 AM
Piro Fyre
23
May 15, 2010 12:34 PM
Green_Bandit
18
Aug 21, 2007 09:14 PM
TrojanMan
Jul 14, 2005 01:38 PM
