Hallman heavy spring
Old Mar 16, 2014 | 07:20 PM
eking's Avatar
Does anyone know where I can get a heavy spring for a hallman boost controller? Mine was supposed to come with both springs and the heavy one was missing.
Old Mar 16, 2014 | 11:32 PM
EvoGSR8's Avatar
Contact hallmen. They'll send it to you.
Old Mar 17, 2014 | 11:42 AM
eking's Avatar
I did, twice and its been over a month. tired of waiting.
Old Mar 17, 2014 | 11:54 AM
jjk23's Avatar
Did you make sure you ordered the "RX" model?
Either way, I'm surprised they haven't gotten back to you.
Good luck.
Old Mar 17, 2014 | 12:07 PM
EvoGSR8's Avatar
I had to wait almost 3 months to get mine.
Old Mar 18, 2014 | 04:21 AM
sparky's Avatar
Why do you want to install this heavier spring in your MBC? I am just wondering why you need this.
Old Mar 18, 2014 | 07:26 AM
eking's Avatar
Yes, I ordered the RX. The reason is, The RX comes pre-loaded with the light spring and can only be set to stock PSI, or lower. The heavy spring is supposed to be included, but was not in the box.
Old Mar 18, 2014 | 07:51 AM
Ev0ikon's Avatar
I use the light spring and has no problem controlling my GT35R on meth injection. Not sure if you really need the heavier srping.
Old Mar 18, 2014 | 05:08 PM
sparky's Avatar
Originally Posted by eking
..... The reason is that...the RX comes pre-loaded with the light spring and can only be set to stock PSI, or lower..
Nope, I think that you are mistaken in making this generalization. Well, in a way and up to a point you are right, under certain conditions. But you are wrong about not being able run peak boost levels that are higher than stock with the light spring.
Incidentally, how high are you trying to boost?
Old Mar 19, 2014 | 05:41 AM
sparky's Avatar
Think of it this way: An MBC device controls a certain range of boost ABOVE the turbo's total wastegate spring pressure level. Your turbo's spring pressure level equals the 16G turbos base pressure(approximately 8-10#) plus any additional "preload" obtained from adjusting the WGA.
From the factory total spring pressure is about 10-12#. So your Hallman light spring has about a 10# range on top of the 10-12# of the turbos spring pressure. So, your turbo is gonna peak out at about 19-22#.
By simply adjusting the WGA you can increase spring pressure up to a higher level. Your MBC will still have the same 10# range of adjustability above spring pressure, but since the spring pressure is set higher(lets say 17#) the MBC will now start to control boost upwards of 17#. So, you should be able to raise peak boost level up to 27#.
Old Mar 19, 2014 | 11:01 AM
EvoGSR8's Avatar
I also had the same problem and once I got the heavier spring I was able to make above 17psi.
CO_VR4
Dec 22, 2016 05:59 PM
AdamWest
May 3, 2011 08:15 PM
SLVRNBLK
Jan 13, 2006 01:18 AM
scottatyamaha
16
Feb 28, 2004 07:34 AM
