AIT Bung Plug?
Old Apr 20, 2014 | 07:05 PM
sworddemon's Avatar
AIT Bung Plug?
Didn't know if Anyone found a plug for the AIT sensor. I bought nisei engineering UICP and am not running speed density quite yet. I've searched for hours and read through this https://www.evolutionm.net/forums/ev...bolt-plug.html, but can't find an answer. So any help is much appreciated
Old Apr 21, 2014 | 05:19 AM
MRolla's Avatar
Hardware store you will find one. Just take the pipe with you. Look at the plumbing section.
Old Apr 21, 2014 | 07:18 AM
sworddemon's Avatar
I went to advance auto and they sent me to home Depot, home depot sent me to pep boys, and by that time it was 9:00 and they closed...
Old Apr 21, 2014 | 08:43 AM
sworddemon's Avatar
I'm even considering if I should just weld a cap over the bung and when I switch to speed density grind it of. Anybody?
Old Apr 21, 2014 | 09:20 AM
DSMolition's Avatar
The threads are 3/8" NPT pipe thread. Maybe tell that to the incompetent salesmen. There should be no issues to find one at a hardware store. you can always just go get the 20$ gm sensor and install it without using it..
Old Apr 21, 2014 | 09:48 AM
sworddemon's Avatar
Is the sensor just $20? I thought it was about $180. Or I'm thinking of the speed density kit. And when I went to pep boys I said it was a GM sensor, but he couldn't find one that fit.
Old Apr 21, 2014 | 09:58 AM
DSMolition's Avatar
Originally Posted by sworddemon
Is the sensor just $20? I thought it was about $180. Or I'm thinking of the speed density kit. And when I went to pep boys I said it was a GM sensor, but the couldn't find one that fits.
I can sell you one for 180 if you want
https://www.google.com/search?q=gm+i...A&ved=0CAgQ_AU
They are all pretty much the same 5v variable thermistor.
Old Apr 24, 2014 | 09:51 AM
steven121's Avatar
3/8" with a flare tip
Previous experience... For some readon the iat sensor from gm is not a direct screw on unless you can find a flare tip
I just got tap set and rethreaded it so it will screw on without the flare
LowTech302
May 17, 2015 02:04 PM
LowTech302
May 12, 2015 03:17 PM
LowTech302
May 3, 2015 01:59 PM
LowTech302
May 3, 2015 01:56 PM
thatsMR2u
15
Jan 31, 2007 09:44 AM
