tap oil feed for oil pressure
Old Jul 16, 2014 | 08:21 PM
mberenis's Avatar
Running an fp black with oil feed from the oil filter housing which left an opportune location at the head for an oil pressure sensor. Any reason not to use the origin oem spot on the head for an oil pressure source? Ive got the ams remote line so heat shouldn't be an issue
This is an evo 9 btw. Thanks!
Old Jul 17, 2014 | 10:49 AM
420a-t's Avatar
It will read a lot lower than what the bottom end is seeing for actual oil pressure. The best place is at the oil filter housing
Old Jul 17, 2014 | 05:26 PM
egis's Avatar
oil filter housing provide an accurate reading and a quick mounting solution brother.
Old Jul 18, 2014 | 06:37 AM
mberenis's Avatar
Thank you!!
Old Jul 18, 2014 | 12:20 PM
M4Lki3r's Avatar
Veteran: Marine Corps
Do not bolt/thread the sensor directly to the oil pump. The vibrations from the motor will cause it to leak. Use a line to connect it to the pump housing and mount the sensor to the frame or something solid.
Old Jul 18, 2014 | 03:31 PM
420a-t's Avatar
And by oil pump, he means oil filter housing
Old Jul 20, 2014 | 11:51 AM
WWJPD's Avatar
Not to hijack the thread but is this necessary for all pressure senders? Some of them seem huge and bulky where this may be a issue. My aem one seems pretty small and light weight (very similar to the oem sensor). Could engine vibrations still cause it to crack? For people who have had them fail, what brand were they?
Biggy VIII
Aug 9, 2016 03:06 PM
EvO_essence
14
Jun 21, 2016 11:47 PM
ILoveAWD
Jan 4, 2015 05:52 AM
craigybaby37
Oct 21, 2011 01:09 PM
Randy
Mar 12, 2007 11:06 AM
