400HP goal with E85, what other parts am i missing??
The guy that sold it to me said I need a 1.75 to 2.5" for stock turbo. ETS has the one I just mentioned and the one you mentioned. So which one is it? LOL
Good to know! I've seen a post here somewhere that stock cams are good up to 400WHP. But I heard good reviews on cosworth and I got mine very cheap so I cant complain.
I also just ordered FP ported turbo cover for my stock turbo since im gonna be installing 02 housing, ets LICP, new exhaust manifold studs, new gaskets so might aswell at the same time upgrade to new turbo cover, should sound awesome according to many posts.
ok few days ago i received my new ported fp cover and omni 4 bar map sensor.
already ordered t bolt clamps, new manifold studs and nuts, new couplers for ets licp and fp cover.
i think all thats left if grimmspeed 3 port boost controller and new gaskets.
just called the tuner and he said its fine to do it but gotta stay out of boost. I cant get it towed so i have to drive it there. I wonder if i can change it on the parking lot before the tune really quick, it doesnt look like its gonna be a problem to change them.
sure,you can do it any time.about 30 min work.either way you will save $100.
All i got left to install is walbro 255 which ill do tonight if all goes well, 4 port map boost controller and injectors day of install.
mod list update:
ETS 3" intercooler
Megan manifold.
Injen UICP, Intake
ETS V2 LICP
Synapse Diverter/bov
Buschur 3" Downpipe
Works Test Pipe
Greddy TI-C 3" catback.
Aluminum Radiator.
Walbro255 modded(to be installed)
Cosworth 272 M2
RC 1200cc Injectors (will install before tune)
DME o2 housing
Stock Evo9 turbo with FP ported cover.
Stock wastegate.
T-bolt clamps (need to buy more)
I was told to replace stock wga with aftermarket one with stiffer spring before the tune.bought kinugawa with 25psi spring.talk to your tuner about that as well.or maybe you can crank the stock one.not sure.
ok just called the tuner and he said that since im on the stock turbo its not really necessary since he believes we are not going to push that much psi with stock turbo. So im leaving the stock one on to see what happens since i dont have time to order a new one and get it on time since im getting tuned this coming up tuesday. I have to make a separate trip to get tuned on e85 so just incase i do need to replace the wastegate i will do it then when i bring it back.
also i told him that i got 4 port omni map with grimmspeed 3 port to tune and he said no problem.
Also for those of you who are thinking about getting FP cover for stock turbo, it sounds pretty nice but not worth all the trouble unless the turbo is out of the car. LOL
Only reason i changed it because i wanted to pull the turbo out to change the exhaust manifold studs, gaskets and o2 housing so i did the FP cover too.
If i had to go through all the trouble that i went through just for the cover alone i would hate myself. LOL
So just saying and like the other people on here are saying, dont do it unless you have the turbo already out, then its fine.
o2 housing gave me some troubles too, there would be no way for me to undo some of the bolts without the turbo being out, i used a ton of PB blaster and still had troubles. The oxygen sensor would not come out for nothing, we ended up cutting the stock o2 housing to get the sensor out. Main part of my troubles is because my car came from up north and has some rust. rust just kills everything
ok i got my car dyno tuned yesterday.
Everything worked out pretty good, had few small issues but got it all worked out. The car did 350whp and 317tq at 22psi on pump 93. I will be bringing it back for e85 but they recommend swapping walbro 255 for a better pump, im guessing a double pumper.
im very happy with the results and now i do think that making 400whp mark shouldnt be an issue.
