Evo IV/V/VI - 5th Gen Mirage Sedan Headlamp compatability
Sup evom, new here, been lurking a bit, did a search and couldnt really find any good info on what I need.
Basically, I'm looking to to import an Evo IV/V/VI from Japan. However, where I live, to get the car registered you need to have DOT approved headlamps. The whole assembly needs to have the marking on it.
After a bit of searching it seems as though the word-of-mouth solution is to get your hands on some USDM mirage sedan headlamps and swap them into your evo. But i've only ever seen people suggest this for evo IV-VI. While the IV-VI are based on the 5th gen Mirage chassis, it does make sense and the actual lamps do look identical in photos. But still, i've never seen anyone do it.
So I browsed a couple auto part shop sites and actually found some 5th gen mirage sedan headlamps, for cheap too.
http://www.rockauto.com/catalog/rafr...parttype=10762
So does anyone have experience or knowledge with this specific thing? Will these actually fit in any of the IV/V/VI without extensive modification?
The evo4-6 headlights are the same as the base lancer/mirage, IE they are ****. So yep, grab some off the base lancer/mirage and go nuts.
However the evo5-6 used the facelift version headlights which are more rectangle, do an image search and you'll see.
I've seen people fit those one piece headlights, just having to cut out some of the guard support bracket around the indicator area.
Seems a bit rough to me though so i've stayed with the factory stuff but fitted one of those HID projector kits, heaps better than the factory lights.
WTB[Mid-Atlantic]: WTB: coilovers for evo 4 5 6 iv,v,vi
suddoth1
Aug 15, 2016 12:46 PM
TigOLDBiTTies
23
Jun 24, 2013 07:12 AM
drahte1905
10
Feb 1, 2012 01:13 PM
