Boost problem
Old Sep 29, 2014 | 06:07 AM
Mik6222's Avatar
Boost problem
Ok so I replaced the actuator ( put a 8 actuator in my 6 ) all went well the boost cut is gone, but now I'm facing another problem which is slowly happening more. I'll come on boost and sometimes I'd get full boost but at times I won't be getting anything. It was happening with the old actuator too except with old one it will boost cut. Mostly in 1st and feels like the turbo is sort of choking
Slight shaft play in turbo nothing major, doesn't blow smoke. Stock evo 6 turbo with 8 blow off ( apparently ) any opinions what it could be. Would a manifold/exhaust gasket do this? Thanks!
Old Sep 29, 2014 | 06:17 AM
Mik6222's Avatar
Also forgot to mention I'm running stock boost
Old Sep 30, 2014 | 04:08 AM
OkinawaFD3S's Avatar
That's really strange. I'd hate that. Sorry I can't help, but I'll give you a bump in hopes someone can offer some advice.
Old Sep 30, 2014 | 05:53 AM
Mik6222's Avatar
Thanks mate, yeah it's doing my head in. If it was doing it all the time it would make life easier. Hopefully someone can help.
Old Oct 2, 2014 | 01:09 AM
Mik6222's Avatar
Bump - anyone have any idea?
Old Oct 2, 2014 | 02:28 AM
iD33's Avatar
Boost controller? I would try to hook up a compressor to the WG actuator and see if it opens at a certain psi.
Old Oct 2, 2014 | 04:13 AM
Mik6222's Avatar
Standard never boosted, it was still sluggish with the old actuator but the old actuator used to boost cut, so I changed the actuator and it slugs here and there sometimes without boost cut now
Old Oct 5, 2014 | 07:50 AM
Mik6222's Avatar
Spotted a slight oil leak seeping through the turbo flange, anyone think this could be the reason why? Gasket?
Old Oct 10, 2014 | 04:32 AM
sparky's Avatar
Is it fitted with the black, plastic VIII diverter valve?
Old Oct 10, 2014 | 08:47 AM
Mik6222's Avatar
Yeah, from memory it is but I'll double check!
Old Oct 10, 2014 | 09:11 AM
sujinX's Avatar
have you tried a boost leak test? check the turbo, the oil seeping sounds like a problem.
Old Oct 10, 2014 | 08:05 PM
Mik6222's Avatar
Haven't tried boost leak test yet, that was going to be my next step. Thinking of just taking it past a workshop when I have time get them to go over the car. It's whining abit when driving now not too sure where it's coming from, also knocking when turning anyone have an idea? Cheers
vr4gasmtt
Nov 7, 2014 06:14 PM
Red08EVO
Mar 9, 2009 06:57 PM
wingnut
Jan 20, 2005 11:11 AM
blue beast
Mar 29, 2004 02:52 PM
