OEM ECU - anyone know how high the cold start settings/rpm for OEM?
Old Oct 3, 2014 | 08:49 PM
wowzers's Avatar
Hi guys
I recently had my car tuned and I'm not too happy with how the tuner set the cold start RPMS.
Firstly, the operating temp idle is now at 1,100rpm… which is fine.. it sounds so much better than the 900rpm OEM idle.
However, i never recalled how high the OEM cold idle was set at?
(something like 1,800+rpm?)
How the tuner set it, I'm not sure...the car sounds lazy on cold start and immediately after cranking climbs to about 1,400rpm… and slowly falls down to 1,100rpm.
i hadn't started the car for two weeks and it took 2 cranks and it a loud 'P O P!!!!!!!!!!!!' and then climbed to 1,400rpm..
I seriously miss the way it used to crank and sounds insane at 1,800+rpm and then you hear the automatic choke drop.
So does anyone know what cold idle from OEM is set as?
I'm thinking of going back to the tuner and instruct him to set the cold idle how it was.
Old Oct 4, 2014 | 06:55 AM
EatSleepBoost's Avatar
You need to do some searching or post this question on the EcuFlash section in this forum. Here is a thread that may help.
https://www.evolutionm.net/forums/ec...hramod-v7.html
Old Oct 4, 2014 | 07:31 AM
wowzers's Avatar
FYI,
1.) that thread did not help at all. There was no rock-solid answers. It relates to the OP having issues with his tuning. Which is different to my question.
2,) Why should i be posting it to ECU flash… I'm not concerned with whats ECU flashes are set to.… i was asking for OEM non molestered RPM… so it is classified as 'General'.
Old Oct 4, 2014 | 08:27 AM
Here is all the factory ROMS
http://evoecu.logic.net/wiki/Downloads
If you want your idle higher just have him flash it higher. My 03 cold start was 1700rpm stock
Old Oct 4, 2014 | 11:07 AM
Biggiesacks's Avatar
Originally Posted by wowzers
FYI,
Ecuflash is the program used to tune evo's. The people that know anything about the tables and their settings would be there. Its clear you are pretty ignorant of the tuning process which is maybe why you are having trouble finding your answer. I would suggest downloading Merlins Evo tuning guide (search for it) and do some reading and educate yourself. Other then that you should talk to your tuner and have him adjust it to your liking.
Old Oct 4, 2014 | 04:11 PM
wowzers's Avatar
Cheers, thats all i need to know.
Dude, not everyone knows everything.
like i said earlier, i was after just one simple figure ('1,700rpm')
And you mentioned to talk to your tuner to adjust it to my liking.
well obviously i am going to do that aren't i?!… to my liking… i already mentioned that i prefer how it was OEM…. and thats all i was asking for.
not everyone needs, wants to, has the time or interested to read a book of tuning if there are after one simple 4 digit number when someone can just simply answer that question.
Old Oct 4, 2014 | 04:31 PM
well if you did any research at all you would know that it isnt just one four digit number but several different tables that control ISCV initial position , iscv decay etc that all play into what your idle will be when you first start the car. If you arent interested in learning about this stuff then i really dont see the point of you making this thread. A simple email/call to your tuner was all that was really necessary. I understand you don't know what you don't know, but a certain level of humility is called for when asking people for help, and your post #3 where you basically second guess peoples advice seems arrogant.
Old Oct 5, 2014 | 04:53 PM
wowzers's Avatar
This i forum, people ask questions.
And for you information people do search and what if they couldn't find it?…No one is perfect.
For the last time….I did not need to know ISCV, tables etc.
ALL I ASKED was "1,700rpm"… then pass this on to the tuner, DONE!
You accuse me of making this thread, well i can say like wise; if you are that pessimistic to begin with, you don't need to reply to this thread.
Yes i agree, a certain level of humility should be called for when you had need of dropping your 2 cents and made the excuse of "helping" but yet, displaying narrow-minded bigotry behaviour.
Old Oct 6, 2014 | 01:16 PM
You spent half your first post describing how your car behaves when you first start it cold, and how you want it. The tables i described have everything to do with controlling that behavior. It seems like the one being narrow minded here is you, declaring you are not interested in learning and dismissing what people are advising you to do. How am i acting like a bigot? Do you even know what that word means?
Old Oct 7, 2014 | 03:56 AM
wowzers's Avatar
Im very certain, that you buddy….have other….First World Problems to worry about, elsewhere.
kthnxbai
Old Oct 7, 2014 | 09:57 AM
Im certain you have backed yourself into a corner with your poorly chosen comments, and are now resorting to personal attacks to try and save face. Why dont you do us all a favor, reflect on how this thread went down, and try and do better next time.
ziad
Jun 3, 2010 09:29 PM
leecavturbo
Jul 15, 2008 06:08 AM
acidandroid
May 6, 2005 11:15 PM
cacrawfo
AEM EMS
Feb 8, 2004 08:13 PM
