evo keeps stalling help!!!
Old Dec 31, 2014 | 01:14 PM
hastievo8's Avatar
Hey guys so I have an evo 8. Pretty much stock. All I have done was a act 6 puck clutch grimmspeed electronic boost controller and a tune. Now the car was running fine until last night. The whole day it ran good. Until the afternoon I was at a light and just died on me. I tried cranking it over and would not start. After a while it started up but idled rough. I drove it and stalled out again. And as I tried to turn it over again it acted like a dead battery. Someone cam and gave me a jump but took a while for it to crank. I figured my battery was going out or alternator. I went to get them checked out and they both tested fine. But they gave me a new battery. I drove for a while and did it again. I cleaned the maf sensor and checked the wires it was all good. What could be the cause of this? ???
Old Dec 31, 2014 | 07:42 PM
01397's Avatar
check fuel pump or fuel pump relay
Old Jan 1, 2015 | 12:12 AM
babaz7's Avatar
I had the same problem with my evo, i upped the RPM in the ECUFLASH program, i cant remember what the proper section is named in the program, havent opened the ecuflash program in over a year.
you find a sub menu where you can tinker with the RPM's, there is a RPM-idle and RPM-drive, you up them both a little so they dont go below 500.
i had the same stalling issue when the clutch is pressed in and now its gone.
Old Jan 2, 2015 | 03:05 AM
hastievo8's Avatar
Um the weird thing is that it only happens in the night when its colder but in the morning when it's warmer runs fine.
2002lancer.oz:(
Lancer Engine Management / Tuning Forums
14
Jan 29, 2012 08:13 AM
JVBEvo5
Oct 8, 2004 05:52 PM
[Cyanide]
10
Aug 4, 2004 12:19 AM
turbolanevo
14
Mar 5, 2004 02:17 PM
rubelcon
16
Oct 15, 2003 04:28 PM
