Brief/abrupt lose of power when in boost?
Old Feb 15, 2015 | 10:01 PM
alexc's Avatar
having a problem i need some help with.
sometimes when in boost it suddenly and abruptly looses its power. the engine doesn't die or anything weird when this happens.
no CEL's
I'm thinking the likely culprit is a boost leak. but it's odd that it doesn't happen every time i go into boost?
if you have a viable idea please let me know
please no joke or un-thought out out answers...
Thanks,
Alex
Old Feb 16, 2015 | 01:09 AM
slvrevo84's Avatar
check your spark plugs..
Old Feb 16, 2015 | 08:53 AM
alexc's Avatar
for some reason my spark plug socket doesnt fit over the plug... looks like it doesn't have enough room in the channel on sides around the plug? never had this problem with it on previous cars
Old Feb 16, 2015 | 09:23 AM
Raptord's Avatar
Sounds like it could be boost cut
Old Feb 16, 2015 | 09:31 AM
RussellDaniel's Avatar
Ignition or fuel cut, change and gap the plugs first...go from there
Old Feb 16, 2015 | 05:03 PM
hutch959's Avatar
if you took some logs... we could tell for sure.
Old Feb 17, 2015 | 10:16 AM
Ev0ikon's Avatar
You have the wrong socket.
If I have to guess it's a combo of boost leak and improper plugs/gaps. Fix those easy issues first, then ask more questions.
Old Feb 17, 2015 | 12:08 PM
newbieEVO8's Avatar
Does your evo still have the "snorkle" for the air box?
If so, check to see if the tabs that hold it in place are broken.
If they are, if is sucking up against the hood and choking the engine off out of air.
I could be way off but it's worth a check.
Old Feb 17, 2015 | 01:17 PM
KnucklesVIII's Avatar
Could be boost leak, or plugs.
Old Feb 22, 2015 | 04:54 PM
alexc's Avatar
i checked and changed the plugs and it did it again after words but finally threw a code this time
P0234- Overboost
its factory tune and the vacuum lines to the boost solenoid seem fine. my guess is the factory boost solenoid is starting to crap out on me?
Old Feb 23, 2015 | 08:06 PM
patryk's Avatar
Sounds like boost leak. Had the same problem when I still had the factory tune. The same code. Turned out it was a small crack in the intercooler. The car was spiking to 22psi and cutting out. Do a boost leak test.
dzraduzit
13
Dec 30, 2008 09:29 PM
trboboost91
Oct 16, 2007 04:24 PM
gabesir
Apr 19, 2005 12:17 PM
JTB
Feb 18, 2005 02:16 PM
phantom0429
Jan 29, 2005 12:03 PM
