tps sensor helppppp
Old Mar 21, 2015 | 07:45 PM
Teal2nnr's Avatar
You just have to adjust the TPS. 5.00v full open, and i set mine at .073v closed. Just stick a multimeter lead in the middle wire, and the other lead to the negative bat. cable. ( or ground). loosen the tps so you can move the sensor itself. (key on engine off).
You can even just adjust it by using EvoScan. You just have to rotate the TPS until you get the desired %.
Old Mar 22, 2015 | 07:02 AM
turboback1243's Avatar
My middle wire doesn't read .065 it reads .65. .073v would be like 2% in evoscan am I correct? With those directions the tps should be lined up with the tab in the throttle body and rotated up correct?
Old Mar 22, 2015 | 12:29 PM
I have p0122 code saying low tps circut voltage I don't get it the volts are right and the % in evoscan is right wth
Old Mar 22, 2015 | 02:02 PM
I raised the volts to .72 light went,out. Hopefully the base Map makes it idle
Old Mar 22, 2015 | 04:17 PM
Teal2nnr's Avatar
Ya sorry I added a 0. it should work properly now.
Old Mar 22, 2015 | 04:19 PM
Thanks for the info.
Old Mar 24, 2015 | 07:45 PM
It was bad iac
Old Mar 25, 2015 | 12:44 PM
Teal2nnr's Avatar
Originally Posted by turboback1243
It was bad iac
Ah ok, good to know.
srtboostin22
16
Jan 10, 2009 09:13 AM
jeffreyinigo
Jun 18, 2007 11:07 PM
evoboi005
12
May 14, 2007 08:51 PM
Sxhawnn
Oct 28, 2006 01:23 PM
proachbass91
Apr 14, 2003 09:25 PM
