Evo 8 rattle noise? or lifter noise? Help!!
Old Apr 15, 2015 | 12:45 PM
jonwtf416's Avatar
Hey everyone,
I need a bit of help pinpointing where this noise is coming from. Not too sure if it may be an exhaust leak, lifter noise, piston slap, or perhaps something just loose. A bit of background information. The car has a built 2.0 with Wiseco pistons, Oliver Billet I-beams, and GSC S2 Cams. It's a fresh built 2.0 with only 150 miles on it! Any tips, help, or advice is greatly appreciated!!
Thanks!
Also the noise seems to go away when I give it a bit of gas
Old Apr 15, 2015 | 01:05 PM
Ev0ikon's Avatar
Is it me or the noise is not constant?
Old Apr 15, 2015 | 04:27 PM
jonwtf416's Avatar
not constant.. bump for help! the noise goes away when I gave it gas
Old Apr 15, 2015 | 05:41 PM
Ev0ikon's Avatar
I would at least open up the valve cover and look it over.
Old Apr 15, 2015 | 05:52 PM
Harsh476's Avatar
I actually have the same issue right now.
Old Apr 15, 2015 | 09:35 PM
STLEVOIX's Avatar
Sounds top end. Would def pull valve cover to inspect. Did you reuse lifters or are they new? Did you properly bleed them when reinstalled after build?
Rob_GPT
63
Apr 6, 2011 09:21 PM
BushBurninEvo
11
Dec 22, 2005 05:06 PM
GOKOU
Aug 25, 2005 05:49 AM
Kyle R
Apr 4, 2005 03:04 PM
