Gap between headlight & fender on one side
Old May 24, 2015 | 07:56 PM
Kreeker's Avatar
I'm putting my headlights back on and I'm noticing that the driver's side light does not sit flush with the fender. The gasket does not touch the bumper
I don't remember seeing this before I removed the headlight so I'm confused as to what's wrong. All the clips are lining up with the bolt holes and there doesn't seem to be anything blocking it...
Bad:
Good:
Anyone see this before and know how to fix it? Or any ideas...?
Old May 24, 2015 | 10:28 PM
BlackHawk_Tsi's Avatar
loosen all the bolts see if it will shift up and tighten it back down while holding it.
Old May 25, 2015 | 06:32 AM
Kreeker's Avatar
The problem is if line up the headlight so it sits flush with the fender, the clips don't line up... I'm so confused...
Old May 25, 2015 | 08:59 AM
I'm assuming here....
Sounds like frame damage. Improperly jacking up the car maybe?
Not trying to offend. Are you the first owner?
Old May 25, 2015 | 09:51 AM
Kreeker's Avatar
I'm not the first owner, but I've had the car for years and I'm pretty sure I would have noticed this.
I don't even know how you could affect this area by improperly jacking it.
I do know that I'm ready to throw this headlight across the room.
Old May 25, 2015 | 10:27 AM
I feel your pain. I had the same issue when I had some cheap body work done on my eclipse years ago. I didn't notice a gap until I removed the headlights to do some electrical work.
Basically the body shop line up the headlights with shims and bubble gum.... I lived with it.
Hopefully someone else can offer a better assessment.
kyoo
Mar 8, 2016 06:32 PM
Grimgrak
Feb 25, 2015 12:18 PM
tawheed
May 10, 2009 06:04 PM
