Steps to starting Evo after long term storage?
Old Jun 2, 2015 | 01:06 PM
reboundicon's Avatar
Question Steps to starting Evo after long term storage?
Hey Guys.
So I've stored my Evo 9 in a covered storage unit for about 2 years due to the fact that I had another car as my daily driver and didn't have the chance to pull her out much.
Before I stored the car, I had it detailed, I changed brand new oil, I changed the coolant, did a full transmission/transfer/rear diff change, filled the tank up with premium gas and fuel stabilizer, filled the air in the tires with a bit extra PSI, and pulled the battery out. I started the car for about 4-6 months every week, until I finally decided to just pull the battery out completely.
I didn't get a chance to put it on jack stands or drive it on rubber pads (to avoid tire flat spots) or remove all the gas completely from sitting.
Since I want to bring the car out again now, and I'm a super paranoid Evo owner, should I just have the car towed to a reputable garage to have all the seals/gaskets, plugs, fuel system all checked to make sure the engine won't seize up or should I be ok to put in a new battery, check all fluids, visually inspect all gaskets and seals, check tire pressure and start her up?
What other steps should I take before I start the car? What steps should I take after the car is running?
Any help would be appreciated, thanks guys!
Old Jun 2, 2015 | 04:14 PM
Dave123456789's Avatar
new oil as by now theres most likely some moisture in there. crank it over for a bit with the coils disconnected to circulate some oil. fire it up and your away.
check for leaks, warm it up and go for a drive.
Old Jun 2, 2015 | 07:00 PM
LetsGetThisDone's Avatar
change oil, change he fuel out, drive it..
Old Jun 2, 2015 | 10:13 PM
Bladey's Avatar
Change oil, drain and put new fuel in, and also crank for 5-10 seconds with the crank angle sensor unplugged then you should be golden
Old Jun 3, 2015 | 01:14 AM
Jonno99's Avatar
crank to get oil circulating first before you start up....most motor wear is in the first few seconds
Old Jun 3, 2015 | 03:55 AM
rival879's Avatar
I second Jonno. I had my car stored for about 4 years, and this is what I did before starting it:
-remove spark plugs and squirt Marvel Mystery Oil in each cylinder. Let sit overnight
-turn motor by hand by rotating the crank pulley (I checked the direction a few times)
-make sure it rolls; brakes not seized
-inspect fuel pump and filter, drain old fuel
-with spark plugs removed and fuel pump unplugged, use starter (ignition) to crank engine for 15 seconds, 4 times, about a minute apart
-put in new gas
-change coolant
-change oil and filter
-install spark plugs
This may be overkill for you since your storage environment was likely better than mine. When I popped the fuel lines to inspect the pump, the whole system was still pressurized, so I wasn't overly worried about draining out ALL the old gas or flushing the lines. I just emptied most of it and added new with some fuel system treatment.
Last edited by rival879; Jun 3, 2015 at 04:00 AM. Reason: oh yeah, I forgot something
Old Jun 3, 2015 | 06:08 PM
You guy are way to worried about this. fcking start it...
Old Jun 4, 2015 | 08:31 AM
-put in new gas
-change coolant
Thanks for the heads up man, super useful info!
camoner
Feb 28, 2011 06:41 PM
joeyj
Aug 19, 2009 08:56 AM
ch47god
Jul 2, 2007 01:13 AM
ltwayner
Apr 3, 2005 07:26 PM
