Haven't driven my evo for couple years need tips
Due to some circumstances i haven't been able to drive ny evo 8 Besides putting in a new battery anything else i should check on before first start besides oil?
Where and how it was stored will have a lot to do with what you need to do. Stored in a climate controlled garage that was basically never opened... drain the gas, check fluid levels, check air pressure and go enjoy it.
Stored outside under a tarp will take much more to be sure no animals have chewed through wires/hoses or have made nests that could potentially catch fire and things of that nature
Parked outside under a tarp. Should the oil be good in the engine and tranny?
The main issue that I ran into were that my tires were completely shot because the air had gotten low over time and they developed flat spots. Also my brake rotors were in really bad shape from corrosion (don't know if you live in a dry area, might not be an issue).
Definitely change oil and replace fuel.
For that amount if time it wouldn't surprise me if oil leaks may occur,or water leak from water pump.
I would go to extreme and replace coolant and all fluids to be honest.
just my 2cents.
just my 2cents.
vnappy
13
Apr 4, 2018 07:10 PM
Jonno99
May 15, 2016 04:54 AM
Lumpskie
Oct 17, 2014 01:39 PM
UNHASME
Northeast Region
Sep 7, 2011 12:24 PM
SmurfZilla
E85 / Ethanol
May 15, 2009 07:18 AM
