Dw200
Old Dec 21, 2015 | 12:40 PM
pistons4550's Avatar
Dw200
Is anyone using this fuel pump? Will it work for 400awhp on e85? Has anyone encountered fakes? How was the install process and did you need the kit? I tried looking for info but couldnt find much specifically for the dw200 :/
Old Dec 28, 2015 | 03:04 PM
Bump for info
Old Jan 7, 2016 | 05:55 PM
Last bump for info
Old Jan 8, 2016 | 12:25 PM
DSMolition's Avatar
Well this pump flows 255 lph so just compare it to a wally 255.
Yes you will need the kit. It could make 400 on 1000cc and higher injectors at 43 psi pressure
Old Jan 8, 2016 | 01:17 PM
LetsGetThisDone's Avatar
Get a walbro 255.
Old Jan 10, 2016 | 10:17 AM
from everything Ive seen it should out flow the walbro right? Thats what ive read anyway but cant always trust the manufacturer specs.
Old Jan 10, 2016 | 08:53 PM
killerpenguin21's Avatar
You may be thinking of the 300, not the 200?
I have the 300 in my car, zero issues and I basically track only. Using fic 1050sp's I was making around 380whp on VD at I believe around 90% idc (e85, bolt ons, stock cams)
Old Jan 10, 2016 | 10:27 PM
youra6's Avatar
Have one on my Evo and had one on my 2014 and 2006 WRX. Never had an issue with the DW300. The 255 would work just fine and you get get them really cheap used.
Old Jan 11, 2016 | 01:45 PM
DSMolition's Avatar
yes the dw200 (flows 255) see the attached flow chart.
I run a DW300 which flows 320 lph with a set of 1250s and make 400/400 on a mustang dyno with 60-75 peak injector duty cycle at 43.5 psi base pressure. This is with e83. so I have quite a bit more room.
Old Jan 26, 2016 | 11:54 AM
Just an update in case anyone stumbles upon this thread and has the same questions. Pump is working great since my e85 conversion. Made 414/452 on MD. Its very quiet. I will be posting my dyno stuff in the tuning section sometime soon.
Old Jan 26, 2016 | 08:01 PM
edsct9a's Avatar
Did you go with the 200 or 300? Stock wiring or rewire? I'm looking at the 300 with some FIC 1120s.
Old Jan 27, 2016 | 07:02 AM
200. I did the whole e85 coversion at a shop so I did not install, but I didnt give them anything more than the pump and the universal install kit. I believe they used the stock wiring. I paired mine up with some 1100 high z FICs.
Old Jan 27, 2016 | 08:39 AM
Terror Rising's Avatar
I also run a DW200 and I bought it because I didn't want the infamous Walbro whine. I'm surprised you were able to push the 200 that far. You don't happen to know what injector duty cycle you're at, do you?
Old Mar 24, 2016 | 05:26 PM
Sorry for the super late reply, I finally received all my files. Duty cylce logs are in my dyno thread
https://www.evolutionm.net/forums/ev...-evo-tune.html
Old Mar 24, 2016 | 08:10 PM
3gturbo's Avatar
Get a walbro 255.
It used too be the goto pump I have ran several but Im happy with my aeromotive stealth now. Quieter and flows over 30% more.
ace33joe
Dec 19, 2012 05:56 PM
DeatschWerks
Mar 9, 2012 09:10 AM
RallySport Direct
Jan 27, 2012 10:21 PM
