hard start whem warm only if jumped
hello. i have been facing an issue with my warm start ups lately. if the car is cold it fires right up, if the car is warm it has to be jumped and tap the throttle body repeatedly. i replaced 3 new batterys. and a starter. alternator puts out good charge. tuner (pure drive performance) messed with it a little bit and it is still doiing the same problem. any ideas? it only does it when its warm.
evo 8. 4g64 long rod. 280 cams. 6262pt
might be the voltage regulator on the alternator, maybe when it gets hot it cannot regulate the voltage and does not charge the battery, there are diodes in there and they could have possibly gone bad, should not be expensive, but you have to remove the alternator to replace it.
I'm trying to think what that would do: maybe sticking throttle plate, maybe jar the ISC into working, maybe just foot exercise.
You might try a crank at WOT followed by a crank with the throttle closed. If that works it is getting flooded.
Another possibility is that you getting a weak signal from the crank sensor when hot.
I had the same issue with a customer's car, and it turned out to be that he neglected to install the delete plug for the injector resistor pack. If you are running High z injectors, I'd check that out.
I have the resistor box installed and it has always been installed. NY injectors are low z.
bigturboevo80
Jan 1, 2011 04:26 AM
EriCS
10
Feb 12, 2009 08:05 PM
