Evo 8 A/C Compressor spinning and cold lines, no cold air
Here's another symptom:
When I started the car this morning, the AC blew nice and cold. By the time I let the car warm up to get out of the driveway, it was blowing warm air.
Now I'm thinking maybe the air gap is too wide and the clutch isn't engaging once the car warms up and gets out of reach of the magnetic field.
Would the compressor still yield a pressure differential between the high and low side of the AC if this was the case?
Did this just start happening randomly? Or did a component in the system fail, then you re-gassed and now you're here?
Check the accumulator sight glass while the car is at operating temp and the AC is on. Are there bubbles in the sight glass? If there are, you are low on refrigerant.
I would advise that you have the system fully evacuated to ensure that there is no air in there, first of all. Air in the system will result in standard operating pressures but warm air. Secondly, after evacuating, refill the system by WEIGHT, not by pressures.
iirc our AC systems hold approx 550g of r134a +- about 30g i think.
Troubleshooting an expansion valve is a pain in the ***, in my experience. But I don't think that's your issue here.
FWIW: I am not a HVAC tech, i just do my own AC on my vehicle and my friends/family. Consult a professional for proper diagnosis.
Sounds like you have moisture in the system. A new receiver drier and vacuum the system for 30-40 min and charge to the proper weight and recheck from there. Seems like a waste of time to do anything else ar this point till that procedure is done. I do work on ac as part of my job if that helps.
RallySport9
Feb 20, 2016 11:24 PM
MULLDOG
May 21, 2013 07:54 AM
m.s.p
Feb 19, 2009 03:03 PM
MitsuNewbie
Lancer Engine Tech
13
May 5, 2008 06:52 AM
