Ringing sound after TB seals
Old May 22, 2016 | 12:00 PM
edsct9a's Avatar
So a couple weeks ago I removed my TB to replace the seals. After the installation I began to get a type of ringing sound around the vaccuum to boost transition, I'd say around 5inhg-0psi. It didn't happen before this and happen immediately after I reinstalled the TB. Could rotating the plate 180* cause this? Maybe some kind of turbulence. Vaccuum didn't change at idle and the car boosts just fine. Thanks.
Old May 22, 2016 | 12:09 PM
kaj's Avatar
kaj
I would double check that I tighten the screws on the butterfly completely.
Old Jun 14, 2016 | 11:23 AM
edsct9a's Avatar
So I finally pulled off the TB and nothing was loose but the plate wasn't really centered. I held it up to the sun and moved it around until the light looked even all around the border of the plate. Took it out for a drive and the ringing is gone.
Old Jun 14, 2016 | 11:33 AM
Erik@MIL.SPEC's Avatar
Like blowing air across the top of a bottle
Old Jun 14, 2016 | 11:58 AM
kaj's Avatar
kaj
Weird. You shouldn't see light coming through, if its sealed properly.
Do you ever have idle issues?
Old Jun 14, 2016 | 12:11 PM
edsct9a's Avatar
No idle issues. When I had it apart the first time I cleaned it a bit and accidentally took some of the coating off. Maybe that's why but it's a very faint light like looking at an eclipse
Old Jun 14, 2016 | 12:25 PM
kaj's Avatar
kaj
That would splain it. I once took all mine off. I thought it was carbon build up so had to redo it LOL
Bmurray
190
Sep 20, 2017 06:01 PM
chrylaser
Oct 21, 2014 07:14 PM
Huetsimus
22
Oct 15, 2013 10:08 AM
rzrxn
Jul 8, 2013 01:19 PM
EvoSeanzie
Jun 22, 2010 04:42 PM
