Oil light Flickers on taking of
Old Jul 7, 2016 | 01:35 PM
  #31
barneyb's Avatar
Originally Posted by DanielM
with your car already at temperature, come to a complete stop. put it in 1st gear and let go of the clutch slowly no throttle. does your oil light come one ?
I took the car out, A/C on, got it up to temperature, but just to be sure hit the highway for a loop around the city, and then when back at the house tried your test (I needed to mow the lawn - this was better than doing that). The engine idles down to about 400 like in your video. No oil light.
Engine oil is Mobil 1 10W-40 High Mileage.
In your case I would suggest in order
1. Bad oil pressure switch
2. Wrong oil viscosity
3. Worn oil pump
4. Loose fitting bearings
5. Or maybe in my case I just have a tight engine - dunno
Old Jul 7, 2016 | 05:05 PM
  #32
DanielM's Avatar
3. Worn oil pump
Would a worn out timing belt course this ? The car drives perfect but just the idle taking off wants to die and then takes off . I basically have to slip the clutch to take off
Old Jul 7, 2016 | 06:04 PM
  #33
DanielM's Avatar
Oil pump is my next guess or pick up screen
Old Jul 8, 2016 | 10:31 AM
  #34
barneyb's Avatar
No.
Old Jul 8, 2016 | 11:29 AM
  #35
DanielM's Avatar
No.
im pretty sure the oil sensor has nothing to do with the idle droping before taking off and light up the oil light . or am i wrong ?
Old Jul 8, 2016 | 12:47 PM
  #36
barneyb's Avatar
You are correct. I could just be a bad ISC but once after market parts are added the idle is affected. Then what you need is a tune in order to make the engine operate correctly. The thing is, a tuner is going to want to run the engine hard during testing of all modes of operation. You don't want to take a vehicle to a tuner that has an oiling problem. You chance windowing the block. So, sort the oil pressure problem first.
Old Jul 8, 2016 | 01:20 PM
  #37
kaj's Avatar
kaj
The idle drop could have something to do with the light coming on.
Old Jul 8, 2016 | 01:36 PM
  #38
DanielM's Avatar
it does but im not sure if the sensor would cause that problem.. im thinking either my clutch is almost done wich i doubt because it holds power. oil pump,oil pick up screen. im just hoping its nothing really bad. its only have 60k miles and always fresh oil every 3k so im confused at the moment. i dont even drive her no more
ill post more videos later and see if you guys can help me out .. thanks
Old Jul 8, 2016 | 02:51 PM
  #39
barneyb's Avatar
Writing to the forum never fixed anything. You need to get out the wrenches. For starters, change the oil pressure switch.
Old Jul 8, 2016 | 04:23 PM
  #40
kaj's Avatar
kaj
Which problem? The light? Yes. The idle? No.
So to recap:
Can the light come on from a low idle condition? Yes. You would need to find out why the idle is dropping.
It would need to drop really low, though. Low enough to not build oil pressure (our light only comes in if we're pretty much at 0psi LOL). If it's dropping that low while taking off from a stop, learn to drive and your problem will be solved. LOL
If the idle is dropping because of a mechanical issue, then start trouble shooting. Logging with EvoScan or swapping in known working parts would probably be quickest.
Can the light come on from a bad sensor? Yes. Then replace the sensor.
Do work, son! And good luck.
Old Jul 8, 2016 | 04:42 PM
  #41
Solenoid's Avatar
Veteran: Marine Corps
3 pages worth of "change the sensor" Please
Old Jul 8, 2016 | 05:11 PM
  #42
LetsGetThisDone's Avatar
My oil light comes on if I do that and let the rpms dip below 500. Use throttle when you let the clutch. The rpm's shouldn't be going that low anyways.
Old Jul 9, 2016 | 01:28 PM
  #43
barneyb's Avatar
He says a CEL for p0300 has been on for 2 years. Maybe it really is a misfire.
Old Jul 9, 2016 | 01:55 PM
  #44
Ok. But the misfire isn't causing the oil light, nor is it likely that it needs a pressure switch. He needs to fix the misfire, and then keep the rpms up when he's leaving from a stop
Old Jul 9, 2016 | 02:10 PM
  #45
Red_06_EvoRS's Avatar
Agreed. My Evo has done exactly what the OP says his does from new. It spooked me the first time but its only when I'm careless when leaving from a stop and don't feed in enough throttle. I can't imagine a four banger that can leave from a stop without giving it some throttle and not have the RPMs drop.
