someone enlighten me on this issue
Old Jul 28, 2016 | 01:27 PM
tsidrift1's Avatar
Id buy those if the shootout wasnt right around the corner lol.
Old Aug 1, 2016 | 06:25 PM
mitsubishikid's Avatar
Get 2 or 3 cans of carb cleaner, and clean your intake, throttle body,and [if you still have them] isc ,and egr valve and ports, and if you haven't recently done it, replace the fuel filter.
Old Aug 1, 2016 | 10:11 PM
zbestevors's Avatar
Originally Posted by roni4g63
He said car runs fine when he uses his buddys 2150's, pump cant be bad..
Visually inspect the rail and injectors at idle, see if you have fuel coming out of any of them, you can also tell you have a leak somewhere if that certain spot looks really clean compared to the rest of the surrounding area. if all those check out, disconnect the injectors and look at the electrical pins, maybe you have a contact issue on one of them.
basically. if the SAME injectors your bud owns run fine on your car, your problems are your set of injectors. end of story.
I always start with the basic when diagnosing issues so that I don't overlook something. If all checks out that I previously mentioned ok. I would then olm test the injectors and then perform a volume test for each injectors. Next............... R u saying because his buddys injectors work he doesn't need to check power,ground, and resistance? I'm a mastertech and I diagnose properly before I replace a part. I like to know why. Is all his injectors bad or just a few? I don't assume and guess.
Old Aug 1, 2016 | 10:19 PM
zbestevors's Avatar
To be honest sounds strange that his buddys car runs good on both. Im thinking if the mapping may have something to do with it. I would like to find out how this turns out so I can learn something new.
Old Aug 2, 2016 | 10:21 AM
tsidrift1's Avatar
Funny thing about the map is, the car was tuned on the set of injectors that dont let the car run.
efaustin
12
Jul 26, 2014 09:14 PM
Jonesey I7
Jul 30, 2011 01:27 PM
stonecoldcrazy
Mar 8, 2005 07:53 PM
marcopolo
Australian Forum
14
May 24, 2004 03:29 PM
