Questions on AMS REMOTE OIL PRESSURE SENDING UNIT LINE
I believe you don't need an additional fitting if you're using the ams sending unit since it plugs straight into where the hex bolt is and you connect the oil pressure sensor on the female end of the sending unit.
Sorry for the thread jack but I'll be doing a Defi Oil Pressure Gauge install soon. I have the AMS sending unit. The sensor seemed to screw fine onto the AMS sending unit. The ams sending unit has a 1/8 NPT female end and per the 42draftdesigns they said
"Using a Defi gauge?
This adaptor is not for you(This adapter is 3/8" BSPT male thread to 1/8" NPT female threads). Defi oil pressure senders are 1/8" BSPT. You will need to use our BSPT adapter."
So since the ams sending unit is a 1/8 NPT female and my defi needs a 1/8 BSPT. So do I need to get an adapter that is a 1/8 NPT Male to 1/8 BSPT female to get my defi sensor to fit correctly on the AMS sending unit? Or can I just screw the sensor onto the sending unit, use some thread sealant and call it a day?
Thanks.
Thanks.
as long as that fitting AMS supplies is 3/8 BSPT your good to go otherwise using a Def Gaue you would need this adapter for it to work correctly - Lancer EVO 1/8 BSPT Oil Temp/Pressure Adapter
The oil filter housing adapter is 3/8 BSPT ( British Standard Pipe Thread) so you would need the adapter to put into the housing. I won't tell you to but people simply slam the the sensor into the housing with a bunch of pipe dope and call it a day , however I don't suggest it especially per performance and longevity of the senor do it the right way. Your sensor should be 1/8 NPT ( National Pipe Thread), which will then thread into the other end of your remote line and simply mount it to the firewall. Anyone correct me if I'm wrong but I'm almost certain this is all correct
Updated ***After more research I need to get an adapter for the AMS sending unit to the hex screw area since the AMS sending unit comes with a 3/8th NPT instead of a 3/8th BSPT. So I'll probably have to get two additional adapters on top of the AMS sending unit. Cool*** So now I need to do the following to get everything to fit right. Oil filter housing>3/8th BSPT to 1/8th NPT adapter>AMS Sending Unit>Adapter(still trying to figure this one out)>Defi Sensor. I think..
Figured out the thread sizing for the AMS sending unit line from this URL. 5th posting from the bottom explains it.
http://www.evoxforums.com/forums/arc...p/t-44919.html
Person from that post says the following...
"i called ams and they said the 4b11 block has a 3/8th bspt port. but the remote oil pressure sending line has a 3/8th npt. pretty much idk if i should stick the routing line in or not beacuse im worried that itll leak since npt is different from the bspt. he told me itll be fine if i use a little bit of teflon tape and itll seal up from any leaks. i dont want a leak and have it cause problems. should i just put the telfon on and stick it in there or what?
If AMS says that it will work okay, my bet is that it will work okay. Teflon tape is teh ****z."
Ok after research the AMS sending unit line is 3/8th NPT. You will need a 3/8th BSPT to 1/8th npt adapter to put onto the AMS sending unit. So you would unscrew the male piece from the ams sending unit and swap it with the 3/8th bspt to 1/8 npt adapter... I feel its dumb for them to sell this as an application that fits "All 4G63/4B11 equipped Mitsubishi’s"(there website says that) even though it necessarily doesn't.
Yea I get that. So pretty much you can either do the Teflon tape thing on the ends, it shouldn't leak but still possible. Or you can get the correct adapters so you know you won't have any leaks and fitment will be spot on. I think I'll do it the kinda lazy way... I will be using thread sealant instead of teflon on this though.
I just installed a oil pressure gauge yesterday and holy took longer and more painful than I thought it wold be. Taking the hex nut off was a pain. I couldn't get heat on the area because of the propane torch I was using either had a large flame which would burn other rubber things around the area or to small which would go out constantly... Couldn't fit breaker bar and was very close to stripe the hex nut when I finally broke it free(whew).
I used the AMS sending unit, plugged it straight left of the oil filter hex nut. It doesn't go on all the way since it's NPT and the housing is BPST. I used thread sealant and put it on as much as I could(not crazy tight though, didn't want to crack the housing). Better after all and done I don't see any oil leaks. OP, you don't have to use the adapter but if you want to be 100% sure it's a perfect fit you would need to find an adapter that goes from the oil filter housing onto the sending unit. I wouldnt plug the oil pressure sensor straight onto the adapter from the oil filter housing since it could damage the oil pressure sensor from vibrations. The sensor for my defi oil pressure is like a 150 bucks, I ain't got time to buy a new one!
Exactly what was said above. You don't need the extra adapter but its all up to the user. As long as you have no leaks your good, sometimes after application its good to let the Teflon sit for a while depending on what kind you use. But without a doubt remote mounting it is the best way to go especially seeing how much the new sensors cost.
05-EVO-GSR
Aug 25, 2015 08:45 PM
Inprogress
May 15, 2014 06:43 AM
Inprogress
May 15, 2014 06:42 AM
Knightr
Jan 8, 2011 08:45 PM
