fuel pump rewire question
Old Mar 28, 2017 | 10:43 AM
Biggiesacks's Avatar
Originally Posted by nor11384
What is a switched source? Also, my battery is in the trunk so it should be much easier. I don't have to run any wires to the front of the car right?
A switched source is a circuit that only gets power when you turn the ignition key to run. The hob switch needs a boost source, so you will want to install that under the hood, so you will have to run a wire from the relay to the hob switch, then to ground. It might be a good idea to add a small 5 amp fuse to the hob circuit too where ever you tap that in.
Old Mar 28, 2017 | 06:33 PM
nor11384's Avatar
FCOTM Winner
What is a hob switch?
Old Mar 28, 2017 | 07:15 PM
sorry its "hobbs" my bad.
CHeck it out here http://www.spoolinup.com/Hobbs-Switch_p_83.html
Old Mar 28, 2017 | 07:44 PM
Pal215's Avatar
Old Mar 28, 2017 | 09:59 PM
RightSaid fred's Avatar
That's the wrong way to do it.
It's either on or off and at low load you'll be outflowing the reg.
Full of fail.
Old Mar 29, 2017 | 05:26 PM
nor11384's Avatar
FCOTM Winner
oh hell, so which is the right way?
Old Apr 1, 2017 | 07:59 AM
mt057's Avatar
Full of fail.
Funny how people take the time to tell you your wrong but not the time to explain what they believe is "right".
I am going to guess by his statement he feels you should purchase an FPR to actually regulate the higher pressures instead of sneaking around the regulation with a on/off switch for full flow. Just conjecture though.
There is an old saying, "Cheap, Fast, Reliable, pick two".
If you are broke then don't throw money at the car. Take your time, do research, then act once you have saved up enough to afford what you are doing, with out putting yourself or family out.
Old Apr 1, 2017 | 08:01 AM
mt057's Avatar
Also the Walbros can be kinda loud. How bad is it? Are noticing any other problems?
Old Apr 1, 2017 | 08:04 AM
If you look at the spoolinup link to the hobbs switch i posted it actually shows you the correct way to wire it. As far as On/Off goes, the Ecu switches between two modes, low voltage and full voltage. All you are trying to do with the additional circuit is reduce resistance in full voltage mode by adding in more wire. Rightsaid fred generally just goes around **** posting so you can pretty much ignore him.
Old Apr 1, 2017 | 03:23 PM
mt057's Avatar
Thank you for clarifying Biggie. I was wondering if the Hobbs switch was like the old methanol kits. Nothing then full blast. It was fun to tune around.
wizzo 8
Dec 27, 2023 12:15 AM
Blue91lx
Jul 10, 2012 06:24 PM
Justin at STM
31
Mar 30, 2012 06:02 PM
Carloverx
14
Dec 22, 2011 01:00 PM
phil_
Lancer Engine Tech
Oct 8, 2006 06:37 PM
