So dumb question about a MBC and tuning
Old Apr 15, 2017 | 02:24 PM
Evo_Goodness's Avatar
So I have self tuned my car adjust the timing new fuel pump uicp and licp got perfect A/F ratios tightened up the car made it more snappy with 0 counts of knock so now it's time to start adding boost I have decided I want to go with a MBC for ease of simplicity of it all.
Now I know I will have to returned my full and timing maps but is there anything done with the boost maps when running a MBC or are those bypassed pretty much like the fail safes and all that I know you leave the stock boost controller plugged in guessing for no SES but no hoses run to it.
I was just curious if hadn't really seen anything on this
Old Apr 15, 2017 | 02:50 PM
RazorLab's Avatar
The only table you would need to still tune is the boost limit which is a load based table.
Old Apr 15, 2017 | 02:58 PM
Thank you for the reply I have been digging all over trying to find an answer on this but couldn't find anything about tuning with a MBC I can find plenty on a 3port go figure lol
Old Apr 16, 2017 | 02:10 PM
LetsGetThisDone's Avatar
You should run a 3 port for better boost control. It's not that much harder to tune.
Old Apr 17, 2017 | 02:36 AM
Simplicity and here in Oregon we don't have massive temp swings most of the year I might go with a aem tru-boost over a standard MBC
Old Apr 17, 2017 | 02:53 PM
By better boost control I mean you can adjust wastegate duty cycle every 250-500rpm depending on how you set up the WGDC table. So you can better control the low end boost spike, while still getting the turbo to hold more boost out above 5500-6k. And you're using tephra V7 ROM, you have boost-by-gear.
tmaxxman21
Jan 6, 2008 04:11 PM
srt2evo9
Jan 30, 2007 02:56 PM
recompile
Dec 22, 2006 03:57 AM
Evolution2003
Sep 19, 2006 01:31 PM
