Cam, spring install. Clarifications
Old May 14, 2017 | 04:35 AM
dookgvr4's Avatar
Well didn't end up using air. While I was using the euro spring tool, and compressed the valve spring it caused air to leak out. So I didn't want to risk on cylinders 2-3.
My only thought was I was doing it too slow. Or I should have used the compression type tool that lays across the head that I have seen that seems to work quicker than the euro screw in type.
I just did 1-4 when they were at top of stroke then I did 2-3 when they were at top.
I was a good boy and bled my lifters as well.
So long story short I have to retime the belt in addition. That seems to be going alright. I am waiting to pick up my valve cover before I can finish that up. The biggest pain in the *** is getting off the water pump pulley! And I fear that getting it back on may be even more of a pain!
Hope to fire it up in a couple days
Attached Thumbnails Cam, spring install. Clarifications-img_3661.jpg   Cam, spring install. Clarifications-img_3664.jpg   Cam, spring install. Clarifications-img_3663.jpg   Cam, spring install. Clarifications-img_3670.jpg
Old May 14, 2017 | 11:23 AM
4b11slayer's Avatar
Ive done it numerous times.
Tdc
Zipties
Collapse tensioner with rod
Bungee cord sprockets to hood.
Head bolt removal install new torque to spec.
As for the springs i did it with no rope in cylinder and no air in cylinder.
The right way to do it is use a leak down tester to compress cylinder to hold valves up. But the oil coating around valves holds them up pretty well.
Used the euroexport spring tool btw.
Old May 14, 2017 | 02:21 PM
dookgvr4's Avatar
Ah no big deal,
This being the first time I've ventured this far into a car, I was a little hesitant. This is also par for the course on how I learn how to do things unfortunately.... The long hard way.
I definitely have a lot to take away from this, and it should be a lot quicker in the event I ever have to do it again.
Old May 15, 2017 | 09:58 AM
LetsGetThisDone's Avatar
The retainers get "stuck". I always tap them with brass punch and hammer to release brake them free. Then the tool takes them off no problem.
Old May 15, 2017 | 09:34 PM
dookgvr4's Avatar
Came out pretty good👌
Timing belt was the easiest part in my opinion, once I had all the proper tools.
Old May 16, 2017 | 09:57 AM
barneyb's Avatar
If that's your garage floor, WOW! Mine usually looks like the nearest to the door Walmart parking stall.
Old May 16, 2017 | 11:18 AM
Pal215's Avatar
That epoxy garage coating is great as long as you don't let your friends use Autozone spring compressors to lower their Hondas! Never again.
O1OTIO
South Region
Aug 6, 2013 02:18 PM
nollij
Dec 26, 2011 12:45 PM
RavSpec
Evo 'For Sale' Engine Internals and Drivetrain
22
Jun 16, 2007 05:12 AM
stEVOx
Feb 9, 2007 11:21 PM
digdat
20
Dec 4, 2003 08:12 PM
