Evo 8 pump primes on startup car stumbles and pump cuts.help?
Old Aug 10, 2017 | 11:32 PM
RightSaid fred's Avatar
Originally Posted by RUNNING.AMOK
do you feel that it will cut the power to the pump after priming?
The pumps don't "prime".
The pump runs when the key gets to the "start" position.
When you turn the key back to the "run" position, the pump will carry on running if the ECU gets cam and crank signals.
Otherwise it shuts off.
Originally Posted by deylag
Also if your fuel pressure is too high you can start to vaporize the fuel and that would cause vapor lock. Not sure if that would be applicable to your situation just something I read about.
You got that back to front.
You get vapour lock when the fuel pressure is too low and the engine is too hot.
That's the purpose of the fuel pressure solenoid, for hot starts.It increases the fuel pressure.
Old Aug 10, 2017 | 11:42 PM
deylag's Avatar
Probably not but I am not 100% sure. Just spitballing ideas from threads I come across.
The camshaft position sensor could cut fuel and spark too. https://www.evolutionm.net/forums/ev...on-sensor.html
Old Aug 11, 2017 | 08:09 AM
RUNNING.AMOK's Avatar
I have done cam angle. I purchased a crank angle it is next on the list of install. To be honest I am thinking loss of communication with the keys immobilizer is making the most sense. Given the way it died and it's current behavior.
It's starts immediately with the initial fuel it gets, pump cuts immediately and car dies.
Old Aug 11, 2017 | 10:08 AM
deylag's Avatar
Sorry, I misread what you wrote then. You can disable the immobilizer to make sure that it isn't an issue. Just use Ecuflash to disable the immobilizer.
HyaboostaIX
13
Apr 3, 2011 04:27 AM
Evo442
Jan 3, 2007 11:01 PM
saiyanzzrage
Automotosports - Illinois
33
Nov 15, 2006 09:39 AM
blackevoVII
Nov 27, 2004 04:52 PM
Secret Chimp
31
Jan 31, 2004 12:14 PM
