Evo 9 mr 6 speed
From what I've read, the problems with the 6 speed become apparent during track days where the trans temperatures get a lot hotter than they would on the five speed and fourth gear is usually the first to fail. I've had a 6 speed for 4 years from from 400whp and now to 600whp and I've had to replace the main shaft bearing but never had an issue with the gear assemblies.
Hmmm.... well ok this makes a lot of sense. I was curious cause I was just looking around and seeing why everyone changes the 6 speed to a 5 speed. I was curious thou is there no modification or something you can do to make the 6vspeed as strong at the 5 speed?
I have a 6-speed right now on loan from a friend. After driving this car, I would have purchased an MR if I could do it all over again years ago. The 6-speed drives SO much nicer than the 5-speed, and I never tracked my car or launched it or anything so the strength wasn't a concern.
4th gear is physically smaller and there is about half a quart less fluid. Fourth tends to get hot and fail with torque numbers above 350.
I've used both and prefer the 6 because:
1. It shifts better
2. I prefer the gear ratios
3. I prefer the shifter location
The downsides are:
1. expensive as crap to rebuild (due to freight shipping cost)
2. Very little support.
3. Upgraded gear sets are big $$$
I have a broken 6 in my car now. I can't decide between tossing in the 5 I have or selling it and dealing with the 6 until I can afford to get it fixed.
6 > 5 x 1,000,000
1. It shifts better
The downsides are:
6 > 5 x 1,000,000
Thanks every one I really appreciate it. I love all the feedback. Right now I'm looking at a evo 9 mr and was just curious on the 6 speed. If I should get it or not. Also to see if there is any support for it.
They make upgraded gears and synchros for the 6 speed but its not cheap. That being said I'm still rocking my 6 speed but don't plan on making big power. Keep the tq down and be religious with fluid changes and it should last a long time if you drive sensibly.
Evokid03
Mar 21, 2011 12:30 PM
Inprogress
12
Jun 11, 2006 01:08 PM
CarFanatic
Jan 21, 2006 12:20 AM
