Clicking when turning right after cars warmed up and driven for awhile.
Old Jun 23, 2019 | 06:36 AM
Evo8Guy's Avatar
Hey everyone! I’ve had my second Evo now for about 6 months. About 3 months ago I started noticing a slight clicking when turning left but mostly right in first after a complete stop, once the car has been driven for a bit. Since having this issue, I’ve had both front tie rods replaced, rack and pinion, and complete coilovers all around, and front cv joint axles driver side and passenger side. I can not figure out what this noise is, thought about bringing it to a dealership just have a diagnosis. My acd light recently came in too and not sure if those are connected. I’m getting my fluids flushed and adding new t case and rear diff on Monday. Please any info or advice or idea as to what this dumb noise please message me or on here. Thank you guys!
Old Jun 23, 2019 | 07:38 PM
notenoughhp's Avatar
Do you have wheel spacers?
Old Jun 23, 2019 | 07:59 PM
Certainly a tough one to diagnose on the boards, but you certainly have had some serious components replaced, as you noted @Evo8Guy
Could it be as simple as rubbing dust shields on the rotor up front? They bend easy, especially when mounting / dismounting wheels
You noted, after it warms up. Could it be engine pulley related?
Just a thought.
On another point, 2 posts since 2006. Dont be a stranger. Join us more regularly on the boards
Old Jun 24, 2019 | 07:01 PM
Evo8Guy's Avatar
I don’t have wheel spacers. And I work at discount tire, I’ve personally taken and mounted my wheels and tires and haven’t had an issue with anything brake or wheel related. Engine pulley is an option, but I’ve never heard one that was bad. And it’s mainly when I turn right which is odd. Gonna put it on the lift and start it and go through gears while turning the wheels. And yea I was a stranger for a bit lol I’m back for a bit hopefully
Old Jun 24, 2019 | 07:21 PM
Yeah, putting it on the lift & going through a thorough inspection hopefully will reveal the issue
Keep us posted for sure and thanks again for joining us on the boards
Joe
Old Jun 24, 2019 | 07:48 PM
Biggiesacks's Avatar
I think this is a classic CV joint failure symptom. I'd probably start there.
EDIT NM read that you already replaced those, next guess since your having acd light issues maybe something to do with the front diff.
Old Jun 25, 2019 | 07:07 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Wheel bearings?
More far out: cracked wheel?
Old Jun 26, 2019 | 09:01 PM
volcano's Avatar
I had a clicking noise when turning right several years ago... ...it was the wheel bearing starting to go bad. The tech kept saying it couldn't the bearing, but after trying several other things I told him go ahead and change the left bearing anyway. Solved the issue.
Old Jun 27, 2019 | 05:36 PM
Evo8Guy's Avatar
Yea I plan on doing a thorough inspection. And will do! Thanks man
Joe
Old Jun 27, 2019 | 05:37 PM
Evo8Guy's Avatar
I’m going to do an inspection and find out what’s going on, it does it when it’s a left or right turn once warmed up, and I’m also thinking maybe something with the gearbox? When I push the clutch in a slight noise goes away.
Old Jun 27, 2019 | 05:38 PM
Evo8Guy's Avatar
Yea gonna do an inspection and bearings are next
Old Jun 27, 2019 | 05:39 PM
Evo8Guy's Avatar
Gonna look at those next. Good idea
Originally Posted by Butt Dyno
Wheel bearings?
