3D Printing parts
Once upon a time, I saw a post on the site with a 4G63 timing cover off. The person had designed a little tool that fits between the cam-gears. It was 3D printed. This holds the 2 cams in alignment when the timing belt is off if any work is being done. Does anyone know where I can download an STL file or model of this? I want to print one on the 3d printer I have access to that prints in high strength carbon fiber fortified filament.
https://www.thingiverse.com/thing:3925590
you do not need carbon fiber/abs nonsense for this... pla will work fine to hold your cam gears in place
Funny thing is, I have my own 3d printer and we have 2 of them at work. In all of my experience printing things I have never used PLA (which apparently is most common). 99% of the time I print using ABS or PC-ABS, but at work carbon fiber is free and it is ridiculously strong.
i just wanted to point out that it's not needed... pla is just easy to work with for a lot of the 3d printing community...
me personally... i'm stuck using abs because i built the enclosure for it... i've done the upgrades.. now everything's in abs till i switch off to something else lol
ah... in that case if you've got it dialed in and what not for that material... props to you and respect for having awesome gear...
https://www.evolutionm.net/forums/ev...m-project.html
my cap is still tethered to the car... i did your trick with my old miata though haha...
really i just got tired of draping the tether over the latch area...
my 3d printer was on idle so threw this into the mix
