3D Printing parts
Old Oct 4, 2021 | 12:33 PM
  #61
Effoc's Avatar
Made a Speaker adapter for the evo https://www.thingiverse.com/thing:4981915
Old Oct 20, 2021 | 06:07 PM
  #62
Jaraxle's Avatar
Working on a MAF housing. This is a first cut of the design.
It connects to a 5" air filter (thinking GT-500 Ford OEM filter), has a 3.5" diameter for the MAF section to help with scaling (aiming for 600+ to the wheels), and then connects to a 4.0" SCAT hose to go in a flexible manner to the 4" turbo inlet.
MAF prototype
Old Oct 21, 2021 | 12:28 AM
  #63
Jp7's Avatar
Jp7
MAF prototype
FYI - Do you know how intakes usually have some of those "resonator chambers" on the intake plumbing? I deleted mine on my 2000 civic, I printed a plug for the hole out of "PC/ABS" and it has been holding up awesome even know it is exposed to PCV/Crankcase gases and some fuel vapors... not to mention under hood temperatures.
Old Oct 21, 2021 | 01:42 PM
  #64
Jaraxle's Avatar
Yes, and my stock airbox is somewhere buried in the basement. I have PC/ASA, straight ABS, or straight PC. Thinking I might go even more exotic with carbon in PEEK or Nylon, not sure yet.
The printer can do 500C, so any material is possible.
Old Oct 25, 2021 | 05:45 PM
  #65
Jaraxle's Avatar
Prototype in orange PLA for fitment testing:
Old Oct 27, 2021 | 12:48 PM
  #66
deylag's Avatar
Thats a great print! Printed it out on a Prusa or a different 3D printer? Probably took like a day depending on infill percentage.
Old Oct 27, 2021 | 05:15 PM
  #67
Jaraxle's Avatar
I do have respect for Prusa printers....However the printer is actually a massively customized QIDI printer that has an LDO Orbiter 1.5 extruder with Phaetus Dragon hotend. The setup is good for a 120C bed temp and 500C print temp.
It did take 17 hours with CUBIC infill at 30% with 3 walls.
and thank you for the print complement!
Old Oct 28, 2021 | 09:47 PM
  #68
osetsky's Avatar
Hey print wizards, how hard would it be to invent a shift pattern lock plate thing?
Old Oct 29, 2021 | 06:26 PM
  #69
Jaraxle's Avatar
Creating something custom just takes some time to model it. A drawing with dimensions is required. Printing is not hard once your have a solid setup, I don't have "bad prints" ever. However, the time modeling it is the crux
Old Oct 30, 2021 | 06:59 PM
  #70
deylag's Avatar
Maybe you can sketch it out. If I can see what your design requirements are then I can model it.
Old Nov 5, 2021 | 12:00 PM
  #71
Jaraxle's Avatar
It fits perfectly!
Old Aug 14, 2024 | 09:25 AM
  #72
bonlamicq's Avatar
Any center console dash gauge?
Hi guys,
I know is an old thread, but wonder if any of you have done a 3D print of the gauge dash panel for the evo 8/9, I just bought one supposed to be Ortiz but don’t like the finish, so I’m looking for a 3D print version that I’m absolutely sure will looks like original.
also looking for the 2 small trim pieces that have the Recaro seats to ventilate at the back
thanks to all.
Old Feb 13, 2025 | 11:59 AM
  #73
Moonman-GSR's Avatar
Designed and printed a gauge pod for my 60-52mm gauge set up. Still some small tweaks to be made, and different revision of post processing.
Old May 9, 2025 | 01:22 PM
  #74
Luca Bernardi's Avatar
if anyone is intrested i made myself carbonfiber sun visors, i can share the stl files, also the 2 clips holding the back seat
plenty of room for improvement, but was a good start
Old May 11, 2025 | 10:47 PM
  #75
deylag's Avatar
Nice idea! I barely use the sun visors as mirrors so larger ones would be a great improvement.
