Stuttering after lugg
Old Oct 1, 2019 | 07:25 PM
Timmmay's Avatar
2006 evo 9 fully built English racing motor
Came to red light and I left it in 2nd lugged it and shifted then it felt like it went into limp mode got home and sounds like a subi. Well I decided to check cop connections 3 changed 1 didn’t so when I pulled them all kinda looked like smoke coming out of rubber boot pugs where scorched on top and smelled like fuel. Cleaned them put them back in for ****s and giggles now idles perfect but then if I start to build boost sputters. Can what happened fouled plugs fried coils both no cel light either
ordered
Denso Replacement Direct Ignition Coil 673-1306
ngk 5245 ilfr7h
hoping this fixes it I’ve also looked everywhere for leaks haven’t found any
any help or ideas much appreciated
Old Oct 2, 2019 | 09:18 AM
blackline's Avatar
5 Year Member
What do you have the plugs gaped at? Gap specs
I had a similar issue that was caused by the plug gap.
Old Oct 2, 2019 | 04:42 PM
Timmmay's Avatar
holy shnikes
you are the man thank you so much I had pulled old plugs Gap was close to 20 so I set them at that then it hmjust ran like garbage pulled set at 22 back in business
no homo love you
Old Oct 2, 2019 | 05:53 PM
LetsGetThisDone's Avatar
The gap is supposed to be .020" and changing the spark plug gap from .020" to .022" certainly didn't fix a misfire like the one you described.
You have an ignition system issue. Likely a loose connection in the COP that fixed itself when you removed and reinstalled everything.
Old Oct 2, 2019 | 06:28 PM
Timmmay's Avatar
maybe but gap at 20 the feeler was a little snug so when I gap at 22 it was snug and put back in everything good
so idk
Old Oct 2, 2019 | 07:08 PM
so idk
You don't know. But I do.
Old Oct 3, 2019 | 04:54 AM
Project_Broke's Avatar
More than likely messed with the actual issue inadvertently. That gap change won't do much, it wasn't out of the ordinary to begin with.
Teal2nnr
Feb 25, 2017 10:55 PM
Adzel94
Feb 14, 2015 12:12 PM
Nismo2evoawd
Nov 23, 2013 02:40 PM
re-rx7
Oct 21, 2012 02:24 PM
PurEvo
Sep 19, 2010 05:01 PM
