Evo starter options
Old Mar 13, 2020 | 03:03 PM
cficare68's Avatar
Lol. The clutch had nothing to do with killing the starters.
Yep you're right. Cause putting a heavier load on something than what it was orignially intended for has zero affect on the wear and tear of an item. As usual you know everything....
Old Mar 13, 2020 | 03:20 PM
Biggiesacks's Avatar
I dunno, I would probably be a little more suspicious of the machining of the flywheel than the clutch itself. I could see it maybe not being perfectly round and pushing against the starter or something like that.
I kinda wonder what the weight difference even is? I would imagine most of these kits come with aluminum flywheels vs the stock cast Iron so it might be a wash?
Old Mar 13, 2020 | 03:22 PM
LetsGetThisDone's Avatar
A few lbs in the weight of the flywheel is of little consequence vs the rest of the stuff being turned over in the engine, as well as the compression stroke.
Old Mar 13, 2020 | 03:42 PM
cficare68's Avatar
Sure if you say so. Like I said you know everything......
Old Mar 13, 2020 | 03:50 PM
I don't know everything. It just seems like it because I'm constantly correcting misinformation that gets posted here.
Old Mar 13, 2020 | 06:49 PM
cficare68's Avatar
Can't speak for all multi disc flywheels. But I do know the one on my Exedy Triple isn't aluminum.
Old Mar 13, 2020 | 07:18 PM
Wow they are really using a cast iron flywheel? You would think with how expensive those kits are they would be using something a little higher end.
Edit: After looking it up they say its "Lightweight chromoly steel" So i assume they mean light weight compared to a stock cast unit?
Old Mar 13, 2020 | 08:32 PM
kaj's Avatar
kaj
Yes. Chromoly isn't bad at all.
Old Mar 13, 2020 | 11:49 PM
cficare68's Avatar
Still not that much of a weight savings. OEM Flywheel weights about 13.9 lbs. The exedy FM12 flywheel weighs about 11.8 w/out the flywheel ring. Add that to the equation and they are about the same.
Old Mar 17, 2020 | 01:32 PM
barneyb's Avatar
Maybe the starter it came with needs brushes or something stupid easy to fix, maybe some lube and maintenance. I bought a Amazon Chinese starter for my wife's WRX and it worked a couple of months and then quit. When I disassembled it I found a well made starter that had been assembled with no lube. A case of people building parts for cars that don't own or work on cars. I added a little lube and its been working great for about 1.5 years now.
SaulHudson
Nov 18, 2014 03:32 PM
evoson23
May 31, 2013 11:09 PM
Charlie-Y
Dec 30, 2010 05:50 PM
Nomad4g63
Feb 22, 2010 12:52 PM
marylandevo8
Dec 8, 2009 09:16 AM
