Front seat mounting stud question
Old May 3, 2020 | 08:33 AM
wwevo9rs's Avatar
Hello all, I have a question about the front seat mounting stud. I purchased an Evo 9 and found this while cleaning the carpets. Looks like one of the front studs on the passenger seat had snapped off. I imagine there are others like this out there. What are the methods you guys have used to repair this? I haven't taken the seat out to inspect further, just saw what is shown in this picture I took so far. Thanks in advance.
Old May 3, 2020 | 11:13 AM
Well, that is a tough bugger
Aside from drilling that out completely, wonder if tapping the bolt shank & going in w/a much small diameter high strength bolt would work?
Or, if cutting out the subpan & making a window (adjacent to the failed bolt) from the interior side, can we get to that bolt shank & replace it w/a new one?
Old May 3, 2020 | 05:25 PM
kyoo's Avatar
i'd just try to weld something on there i guess
Old May 4, 2020 | 05:40 PM
Exsubie22's Avatar
Do they make a oem stud to repair this?
Old May 5, 2020 | 05:14 PM
hutch959's Avatar
i wonder if it would be easier to drill another hole to one side of the bolt all the way through.. and then just bolt it up.
drilling out that bolt will be tough
Old May 5, 2020 | 07:35 PM
kyoo's Avatar
forgive my ignorance, can't u just weld a new stud on there? will it not be strong enough?
Old May 6, 2020 | 04:41 PM
hutch959's Avatar
might work.. would have to pull out the carpet.. grind it down smooth and the weld one on.
if you didnt do that, i dont know how you could cleanly weld one close enough so that a nut would pull up
Old May 7, 2020 | 06:31 PM
kyoo's Avatar
wouldn't have to pull the whole carpet, just pull up in that area? I replaced the entire carpet on my evo once, if I can do it, it ain't hard lol
Old May 7, 2020 | 06:46 PM
Welding on a stud to the failed bolt doesnt sound structural to me. These seats need a stud that is strong in shear & clamp force
Wonder if drilling out the failed stud & dropping in a Nut-Sert device would work. Welding the Nut-Sert in place (just a thought!)
cstylez52
Jul 12, 2011 05:45 AM
Chameleonzero
Jan 2, 2010 08:32 PM
jpetro10
Mar 5, 2008 07:48 PM
dryad001
Dec 7, 2004 05:38 PM
