Oil filter housing questions
Old Sep 13, 2020 | 03:56 PM
raverthug's Avatar
I have an evo 8 with an evo 9 filter housing. Im trying to figure out the best way to do all this. I am going to add an aem pressure gauge. would it be best to put in a filter sandwich, find an adapter for one of the plugs or something else? Also in order to plug the oem sensor hole, what is the threading?
Old Sep 13, 2020 | 04:06 PM
Im running the same AEM setup & i chose, out of being lazy, to do the sandwich. Its not the way our purists will advise as it does space down the filter & is a bit of sore thumb hanging down. Dont do what ive done LOL
Not sure about the thread type?
Old Sep 13, 2020 | 04:17 PM
hutch959's Avatar
stm sells the lines that screw into the plug holes.
Old Sep 14, 2020 | 06:18 AM
blackline's Avatar
5 Year Member
You can take out one of the plugs on the OFH and use this line to connect the Oil pressure gauge.
https://www.maperformance.com/produc...s-01-04-0104-1
Old Sep 14, 2020 | 08:29 AM
240Z TwinTurbo's Avatar
You need to order a 3/8" BST male to 1/8" NPT female adapter and install it in the port shown below.
Old Sep 14, 2020 | 10:52 AM
LetsGetThisDone's Avatar
The Evo 9 has an 1/8 NPT hole on the filter housing for the OEM sensor location (your Evo9 should have the oil pressure switch on the block). Just use that. 1/8 NPT to -4an, 4an hose to the sensor with the AN adapter fitting on it.
Old Sep 14, 2020 | 05:21 PM
RS200's Avatar
The simplest way would be to use a direct adapter 1/8" NPT to 1/8" BSP: https://www.mcmaster.com/1786N127/
Here's the 3/8" BSP to 1/8" NPT, which is probably the port I'd use: https://www.mcmaster.com/1786N244/
Many people will recommend remote-mounting the sensor to extend its life though, since vibration can affect them. In that case, the AMS line would make it easiest. The sandwich is the last route I'd take.
Old Sep 15, 2020 | 08:06 AM
heel2toe's Avatar
Folks, reread what the OP stated. This is the best answer right here. IX OFH already has an NPT port for the oil pressure switch. He said he has an VIII so that should already be on back of his block hence unused port with no adapter necessary. I'd still remove mount it but no BSPT to NPT needed.
Old Sep 15, 2020 | 05:56 PM
raverthug's Avatar
to clearify, I have an 8 with a 9 ODH. I want to keep the stock sensor and add an aem oil pressure gauge in the OFH. Thank you for all the input its helped alot
Old Sep 16, 2020 | 10:53 AM
Yeah. Hence my reply...
Old Sep 20, 2020 | 10:44 AM
I mounted the sensor directly to the oil filter housing using the $5 adapter (3/8" BST Male to 1/8" NPT female). The $40 remote mount kit says that by not mounting on the housing it extends sensor life, but not sure I have seen any data to support this claim. My original sensor lasted from 2007-2019 before it starting intermittently cutting out so I replaced it with a new one. Just a note on the NPT hole on the OFH, it is located directly across from the CV axle and you have ~2.25" of clearance from the hole to the axle.
LacouK600
Nov 1, 2012 04:48 PM
black_beauty
Sep 5, 2012 06:07 PM
sspeed
Aug 11, 2006 10:57 AM
