ACD Will Not Bleed.. What Size Gauge Adapter to Test?
Old Jul 19, 2021 | 04:43 PM
Turtletron's Avatar
5 Year Member
As the title states I simply cannot get my ACD to bleed. I've tried the usual two person key turning throttle down system (worked for me a couple of years ago) and a vacuum pump on the transfer case nipple. The key method does nothing at all, I just see the fluid level in the hose rise and fall a little. The vacuum method just splurts out drops of ATF endlessly. I've had the ACD pump apart three times to ensure it's put together correctly and everything looks fine.
All I can really do at this point is pull it off the car yet again and try to see if I can't get it bled and pressurizing on a bench and then installing it. Does anyone know what size threads I will need for a gauge adapter? Thanks.
Old Jul 19, 2021 | 06:55 PM
frsh92laser's Avatar
Are all three lights still lit up ? I would double check your connectors , fuse, etc shud be able to bleed it with the key method.
Old Jul 19, 2021 | 09:19 PM
Turtletron's Avatar
5 Year Member
The pump kicks on and makes the usual noise for 20 or so seconds before shutting off and giving me the three lights. Not a drop of fluid comes out.
Old Jul 20, 2021 | 06:34 AM
if the three lights are coming on then your systen still has a fault or an issue.
Old Jul 20, 2021 | 10:35 AM
Turtletron's Avatar
5 Year Member
It's going to do that when bleeding regardless because it will never get up to pressure.
Old Jul 20, 2021 | 01:02 PM
absolutely not, thats not how it works. Check this out it will help you find your fault.
fireroasted
19
Mar 29, 2013 09:48 AM
eXtreme-Speed
Jul 31, 2012 10:06 AM
kaj
Jun 28, 2010 10:52 PM
IownanEvo
Jul 11, 2007 04:15 AM
whiteevo311
Dec 20, 2005 07:43 AM
