Help! Leak by the drive shaft and in front of the block
Old Oct 9, 2021 | 11:58 AM
foot3ch's Avatar
Hello there,
HELP! I did the search before I posted this but some of the threads are very old and the pictures are not available anymore Found two different leaks recently and wanted to get your thoughts:
1. One leak by the drive shaft and TC. See pic. Am I supposed to replace the TC Output Shaft Seal item MR581295 or is it something else? Is this an easy job?
2. Another leak by the front of the block. I couldn't find the source. It loos like it's coming from the oil pan seal but the area above the oil pan !!where the engine meets the oil pan is slightly wet and it doesn't feel like engine oil.
Thanks in advance!
Old Oct 9, 2021 | 04:52 PM
hutch959's Avatar
i cant really see any fluid on any of those pics.
on the transfer case... the seal just pops out and a new one goes in.
Old Oct 9, 2021 | 06:55 PM
foot3ch's Avatar
I took a few pictures but it's not really easy to shoot the fluid. It is just wet around and above the oil pan from the front of the block. I also saw by the timing belt cover. I cannot figure it out whether they are from the same source or two separate ones.
I will order the TC output shaft seal.
Thanks,
Old Oct 10, 2021 | 04:28 PM
hutch959's Avatar
its not oil coming from the turbo drain is it?
they are notorious for leaking
Old Oct 11, 2021 | 04:32 AM
foot3ch's Avatar
It is not. If anything. If it is not coming from the oil seal, it probably comes from one of the oil seals on the timing belt area.
Old Oct 11, 2021 | 04:51 PM
hutch959's Avatar
yea.. .unfortunately just gotta take stuff apart and find it.
Old Oct 12, 2021 | 10:03 AM
ViciousLSD's Avatar
thats a weird oil pan gasket
Evoixswe
Jul 2, 2021 12:26 AM
cerevo
19
May 19, 2019 08:55 PM
Danjul89
24
Dec 29, 2015 05:04 PM
john blaze
Nov 5, 2009 07:50 PM
evovin
12
Apr 25, 2008 10:48 PM
